Are brake shims necessary?
Old 07-15-11, 06:11 AM
subzero32
subzero32's Avatar
Default Are brake shims necessary?
I'm going to change the front pads, do I need to buy a new brake shim set? I threw the old one away on the last brake job.
http://lexus.sewellparts.com/accesso...2000/2575.html
Old 07-15-11, 06:15 AM
porn-adkt
porn-adkt's Avatar
Not necessary to performance but are recommended to for Non-Squeal
Old 07-15-11, 06:32 AM
frantinez
frantinez's Avatar
Any other opinions? I was wondering this myself.
Eric
porn-adkt
porn-adkt's Avatar
Eric
??? Opinions as to what?
Old 07-15-11, 07:17 AM
subzero32
subzero32's Avatar
I'll just skip ordering the shim set and see if it needs it. Thanks guys.
Old 07-15-11, 08:11 AM
starfyrels
Account under Legal Action - Banned
starfyrels's Avatar
when i replaced my axxis pads with the oem pads there was no space for my shims to fit so I did without them, same thing with teh spring clips. Basically the shims are there to take up the extra space when the caliper is not hitting the pad.
Old 07-15-11, 08:25 AM
vwynn
vwynn's Avatar
replaced my pads and just installed the pads without grease or shims. I like it dry.
No probs with braking or noise... for me.
Old 07-15-11, 04:48 PM
raytseng
raytseng's Avatar
buy aftermarket instead of OEM and some have their own shim set included-like akebono proact.
If you haven't replaced the brakehardware (the clips, fit kit) you may want to consider that at same time. cheap also if you go aftermarket, and it's not really rocket science.
I mentioned this before, but OEM pads have a huge chamfer cut out, most likely a redesign to sacrifice stopping power for noise. I always felt shortchanged knowing Lexus basically cut out 30-40% of the braking material.
Picture here:
http://www.lexuspartsworld.com/ProdI...4465-22312.JPG
definitely doesn't look like the original design idea for the pads was followed...
Old 07-19-11, 06:32 PM
92sc300nj
92sc300nj's Avatar
if your using stock pads.. for sure use a shim kit.. keeps it quiet and no squeaks.. aftermarket.. do what they recommend.
love67
Suspension and Brakes
17
03-24-13 06:02 AM
dcrx350
Canada
05-18-11 05:20 AM
lx470man
IS F (2008-2014)
24
02-08-11 11:03 AM
DiauR1
IS F (2008-2014)
49
03-18-10 11:13 PM
ewenpg
06-30-07 08:08 PM
Quick Reply: Are brake shims necessary?
