Suspension issues? I'm burning through tires like a hippy's baggie.
I put on new Sumitomos last summer and have put maybe 9,000 miles on them. I run minimal negative camber. It's not even visibly noticeable. I've read online reviews of the same tires lasting up to 25,000 miles.
I just replaced my rears last week (actually due to a blowout from them being so bald). The tires looked like racing slicks. I blame part of the wear issues on improper inflation by the shop. They were way overinflated and started crowning after a few thousand miles.
I had thought my front tires were still good. The tread all the way across the tire is still knuckle deep, except for the very inside shoulder. I noticed tonight that the threads are now starting to show. I don't think there's any negative camber on the front end, which leads me to to believe that there may be something wrong with the front end suspension.
My question is: what aspects of the suspension up front do I need to be checking into for this sort of problem? I believe my front ball joints are starting to go, but what else should I look for?
Thanks.
Thanks.
I couldn't even tell you the specs on the alignment. I had it done at a reputable shop the day I left for college last year.
I work for a dealership and we've got a new shop that we use for alignment. I'm thinking that after I have the new tires put on within the next week or two that I'll take it there and have it done. I shouldn't really need any negative camber as the fenders are rolled and it only rubs at highway speed over big bumps and dips.
I read somewhere that the ball joints can't be replaced alone and that the control arms need to be completely replaced. Is this true?
Guess that makes sense. I don't supposed the alignment shop would keep that stuff on record, at least not for over a year.
If it were suspension related, instead of alignment, should I be experiencing any certain driving characteristics? Everything feels fine except for a mild, cyclical vibration in front between 70 and 80 MPH. I've had it realigned and balanced since the problem began and it's still there.
I have been running sumitomos for 2 summers now. They seem to wear extremely fast for me as well. Barely get 4 months ~7000 miles out of the before they are bald and showing thread. Ran dunlops before that for twice as long without showing thread or belt
You problem sounds easy.
Do a check to see if your LowerControlArm bushings need to be replaced.
You can find out how the check is done with a very quick search.
I have had to replace two sets of LCAs and bushings on my 3 SCs.
I blew out a new set of toyo TR1s in 2 months even with an allignment.
Solara350
Suspension and Brakes
04-29-17 06:08 AM
01VaporBlueRX
RX - 1st Gen (1999-2003)
11-11-02 03:16 AM
