Sage vs Exact RCA?
Master Thread Closer!!
Both SAGE and EXACT's front RCA are made of high grade aluminum. SAGE is 30mm....while EXACT is 38mm.
SAGE rear RCA is made of high grade aluminum....30mm. EXACT is made of steel....I dont know the height....Im sure Glen can comment on this. Both rears are adjustable for camber...offers 3 fixed camber settings.
I haven't actually gone over the rear Rca's more than a passing glance, I was referring more to the front rca's but even so there is a good chance aluminum could be used to make a rear RCA. Aluminum is less prone to bending than steel but again I would need to sit down and do the math for that particular application. Theoretically it should be possible though.
You Zealand Body's rear RCA is made of high grade aluminum....in fact...their entire line of SS Kits (RCA)...front and rears.... are made of aluminum.
The Sage will stand up better over time do the the material & finish. Just examine your undercarriage for reference.. The exact material and finish can be found on the Exact RCA. Both are great products. But, if you live in the North East & or snow country, I would go with a coated or anodized product.
jcat_350
Suspension and Brakes
34
02-26-09 11:22 PM
