DIY Lower your AWD IS250
Old 05-18-09, 04:11 PM
blue_dlb
blue_dlb's Avatar
Default DIY Lower your AWD IS250
As I was lowering my IS250 AWD, I noticed my front shock assembly was different from the instruction on
https://www.clublexus.com/forums/sus...our-isx50.html
I search but was not able to find anything on AWD so I had to try and figure it out myself. Anyways, below are instruction for IS250 AWD. Atleast for my car it was.
1. Jack up the vehicle. You will either need to put it on jack stands or have two hydrolic jacks for this DIY.
2. Remove the wheels and secure the vehicle from moving around with a block of wood or what ever.
3. Pop the hood and Remove the 3 14mm nut from the shock tower.
4. Remove the 2 10mm bolt that holds the brake fluid lines. Please see image attached.
5. Remove the 1 17mm bolt from the bottom of the shock. also pictured and circled in blue.
SteveO92 (10-23-20)
Old 05-18-09, 04:15 PM
blue_dlb
blue_dlb's Avatar
6. Remove the 1 22mm nut from the lower center of the lower control arm. Please see image attached circled in red.
7. Remove the 1 17 mm nut from the endlink also picture and circled in red.
Old 05-18-09, 04:20 PM
blue_dlb
blue_dlb's Avatar
8. Now remove the little pin holding down the 1 17mm nut and remove the nut until it is flush with the bolt. Please see image attached circled in blue. Do not remove this nut all the way yet. Once you remove it until it is flush with the bolt, rapidly and lightly hammer the head to loosen. Once the bolt falls through the hole, remove the nut all the way.
Old 05-18-09, 04:28 PM
blue_dlb
blue_dlb's Avatar
9. All of the neccessary nut are now off of the bolts. Now you must remove the bolt from the holes. This is where you will need an additional jack if you are not putting your car on jack stands. Jack the lower control arm up and down until you can easy remove the bolt from the hole. This method helps from having to hammer and pry the bolt too much.
10. Look back at the image on the first post. Look for the red circle. This is where the shock is held down. If you lightly tap the base of it, it will come apart.
11. That's it, now you should be able to remove the Shock/Spring assembly.
12. Once the shock/spring assembly is removed, you must remove the 1 17mm nut hold the shocks to the springs.
13. Be careful when removing this nut in step 12 because the pressure of the shocks is high. You can shoot it at an empty box.
14. I laid the shock assembly on the floor, held down the base of the assembly with one foot as i'm removing the nut. Make sure you wear gloves and safety glasses.
15. Put everything back in reverse order .
16. For the rears, you can follow the link in the first post.
17. Lastly, get an alignment and you're done.
Old 05-18-09, 04:30 PM
blue_dlb
blue_dlb's Avatar
PM me if you need services to lowering your isx50 in the socal area.
Thanks.
Old 05-18-09, 05:09 PM
mikez
mikez's Avatar
Good write up!
The difference in front shock assembly is the reason why RWD coilovers wont work on our cars.
Old 05-18-09, 08:18 PM
blue_dlb
blue_dlb's Avatar
^^ thanks. I just got back from the alignment shop and they told me that they cannot align the rears. They told me I needed a camber kit for the rear. Is this true? I'm on eibach pro kit for is250 and cut one coil.
Old 05-18-09, 09:35 PM
sinister2c
sinister2c's Avatar
they can aligned it and adjust only the toe which is all you need with prokit because you will be within camber spec.
I think the front AWD has camber adjustment.
Old 05-19-09, 12:10 AM
Hayk
Hayk's Avatar
Thanks so much for this. I'll need it when I'll be lowering mine.
Old 05-20-09, 02:49 PM
CMooch
8th Gear
CMooch's Avatar
Is there any advantage to separating the spring/shock assembly from that black 'c' shaped bracket, rather than taking it out in one piece? I chose not to disassemble it, and just hammered out that 22mm bolt out of the lower control arm instead.
Old 05-20-09, 05:36 PM
blue_dlb
blue_dlb's Avatar
I found it easier to remove that "c" shape bracket first because i didn't have to hammer the bolt very hard. I didn't wanted to ruin the groves on the "c" shape bolt. Plus removing that 17mm bolt was quick anyways.
Old 04-01-15, 11:27 PM
mandipcarz
mandipcarz's Avatar
Old 04-03-17, 05:56 AM
smitty2919
smitty2919's Avatar
Searching around and found this. Need to do the front shocks and wanted to avoid an alignment! Thanks for the write up.
Old 11-25-19, 01:10 PM
valeoray
valeoray's Avatar
Hi,
Did you have to disconnect the upper control arm and knuckle attachment on the IS AWD?
It is really necessary to remove the tie rod end and the sway bar link connections? Or can the 22mm bolt be loosen with jack under the lower control arm to relieve the pressure?
So in reality, just take out the 3 nuts at the top of the shock and the 22mm bolt then it should come out?
ExplicitT
06-26-20 01:16 PM
lexusisru
Suspension and Brakes
30
01-25-20 04:32 AM
bdpride04
10-26-17 08:57 AM
dangerofs
06-21-12 11:32 AM
Sarorn
11-29-06 06:51 PM
Quick Reply: DIY Lower your AWD IS250
