new brakes still noisy
Old 12-24-08, 12:41 AM
eternaldj
eternaldj's Avatar
Default new brakes still noisy
I got new pads and they still make a loud screeching noise, louder than before actually. The thing is, it only does it at low speeds. I was hoping it'd go away after I used them for awhile, but it's been over 1k miles and it's still doing it. I already used brake cleaner for my rotors and pads, but that didn't do anything.
Old 12-24-08, 07:18 AM
jspecdan
jspecdan's Avatar
1000 miles is a lot for it to be making those sounds.
did you install the included shims? what kind of pads did you buy?
Old 12-24-08, 08:55 AM
AW99GS400
AW99GS400's Avatar
When u install new pads did u turn the brake rotors ? biggest mistake alot people make is not turn the rotors when install new pads, no matter how the old rotors look always TURN THEM.
adrian
Old 12-24-08, 12:24 PM
eternaldj
eternaldj's Avatar
I got the OEM pads and I dropped off my car and had someone else change it so I don't know what they did. I had my rotors resurfaced though.
Old 12-24-08, 12:53 PM
rgarjr
rgarjr's Avatar
Maybe they didn't machine the rotors and just threw on the pads in there.
Old 12-24-08, 03:34 PM
SorrGwa
SorrGwa's Avatar
some pads dont have tappered edges. before installing new pads, i like to grab a file and just take off the edge a little bit. the smooth edge stops some squeeking from happening.
also apply some anti squeel grease to the back of the pads where the caliper touches it.
Old 12-27-08, 03:12 AM
Hennesssy
Hennesssy's Avatar
you might want to bleed the brakes?...not sure if it helps.
Old 12-27-08, 04:30 AM
BossGS4
BossGS4's Avatar
Default Did they re-insatall ALL the brake hardware ?
They probably forgot to do 2 things.
Re-lube the 'ears' of the brake pads where they ride in the stainless clips that they sit in in the caliper
AND/OR
THey lost/did not replace the two springs on top of each brake pad which actually keep the pads pushed apart and AWAY from your rotors when theres no pressure on the predal.
DaveC
Old 01-14-09, 12:30 AM
GS4_Fiend
GS4_Fiend's Avatar
AND/OR
DaveC
Nice to know that. That could be the issue.
Old 01-14-09, 12:31 AM
GS4_Fiend
GS4_Fiend's Avatar
Maybe it's not the front brakes that is making noise... Check the back also.
Old 02-09-09, 03:40 AM
aejaz
aejaz's Avatar
I have the exact same issue.. With my RX300 Brake pads (all|) and Discs(Front) done by Toyota.. Any conclusions on this yet?
Fife
11-09-14 05:33 AM
apdimitri
Suspension and Brakes
09-08-13 06:07 PM
pwrusr
03-23-12 10:29 PM
Benjamin T
Maintenance
09-24-07 08:20 PM
DroppedGS
01-15-05 12:49 AM
Quick Reply: new brakes still noisy
