Anyone with ISF brakes on?
Old 03-08-09, 10:50 AM
  #91
Gator Alum
Gator Alum's Avatar
For you guys with IS-F brakes... My car is on jack stands right now... What do you do about the rear splash guards? The rear IS-F brake rotors are too large for my IS350 splash guards... Did you guys just re-use the splash guards from the front of the vehicle? Please help ASAP!!
Old 03-08-09, 11:10 AM
  #92
javyLSU
2IS OG
javyLSU's Avatar
You can just "unroll" or flatten the lip at the edge of the dust shield or just cut it off.
Javier
Old 03-09-09, 08:10 AM
  #93
sinister2c
sinister2c's Avatar
I just bolted the new rotor to the hub with a lug nut and then used a screwdriver to push the guard back until it cleared the new rotor.
Old 03-09-09, 11:48 AM
  #94
Gator Alum
Gator Alum's Avatar
Originally Posted by Lexus-Parts
Hmmmmmm- never thought about the "unroll". For our test IS350, we chose to cut the rear dust shield similar to the way Lexus calls for cutting of the rear dust shield on the F-Sport rear brakes. We figured we could always go back later to install the new shields if need be (we didn't). We found there just isn't an easy solution to this as to get the real IS-F dust shields on there, you'd have to pull the rear axle. It would have taken us an extra couple hours to install the rear shields as well, we didn't want to worry about damaging the rear bearings.
So as it stands, we have the original (cut) rear dust shields on our IS350 "Test Car".
Darrel
Here is the quote from Darrel from the other thread. I think I'm going to do the "F-sport" method and just cut them.
Old 03-29-12, 07:29 PM
  #95
BernieIS
BernieIS's Avatar
Has anyone ever tried the ISF brakes without the ISF hubs?
Old 01-19-16, 02:55 PM
  #96
badx33
badx33's Avatar
Anyone know how wide is the is350 front caliper compared to the ISF front caliper?
Old 01-19-16, 05:44 PM
  #97
flowrider
flowrider's Avatar
Received 1,829 Likes on 1,291 Posts
^^^^I haven't measured, but I know the IS350 front caliper is a couple of mm's wider than the ISF front caliper. Original ISF wheels won't work on an IS350 without a 5mm spacer due to caliper interference.
Lou
Old 01-19-16, 05:57 PM
  #98
Gville350
Gville350's Avatar
Anyone seen that the new GS-F (probably the RC-F too) have 14.9" rotors? I wonder if this setup would work on a 2IS. Hmmm.
Old 01-26-16, 05:27 AM
  #99
badx33
badx33's Avatar
So I installed the rear ISF calipers on my car today and i had to buy longer studs and use a 8mm spacer. For anyone that has 18's wheels and plan on installing isf brakes you need to check your spacing. Im running 18x9.5 with a 25mm offset in the rear, so now with the 8mm spacer it went down to a 17mm and it finally cleared the caliper.
Old 02-03-16, 10:50 AM
  #100
badx33
badx33's Avatar
Did anyone that installed ISF brakes on a is250/350 feel the pedal different afterwards? It seems to go a bit lower than before. If so is that normal? Should I use thicker brake fluid? thanks..
Old 02-03-16, 01:43 PM
  #101
flowrider
flowrider's Avatar
^^^^Maybe expansion in the lines
Lou
Old 02-04-16, 08:58 AM
  #102
WylieKylie
WylieKylie's Avatar
There is no such thing as thicker brake fluid, and even if there were it wouldn't affect how the pedal feels. The change in pedal feel might be due to a bit of air in the system.
Old 02-04-16, 09:24 AM
  #103
flowrider
flowrider's Avatar
^^^^Yes, no such thing But, if it were air, you could pump the pedal and get the level to raise and feel firm.
Lou
Old 02-04-16, 01:26 PM
  #104
Gville350
Gville350's Avatar
Agreed, air in the lines. Did you flush the system while doing the brake swap or just did the calipers? Did you clamp off each brake line before removing each caliper?
Old 02-04-16, 03:50 PM
  #105
badx33
badx33's Avatar
im swapping calipers and brake lines, I will bleed them a few more times. thanks guys.
Quick Reply: Anyone with ISF brakes on?
