Big Problem with Alignment.... HELP Plz ! !
Hi everyone,
i have been having problems with alignment....in all forms !
i have HKS HyperMAxII Coilovers.. which are Awesome !
but i noticed that every single tyre that blew up.. it blew up from wearing the inside of the wheel.. soo it seems like there is a problem with my camber adjsutment maybe?!!?!? plz help..!
in addition, the entire car shakes.. well not very agressive.. but i do feel it all the time on the steering wheel.. on 120 km/h .. i blv !
soo your help.. would probably save my life.. heheh !
Your reply is highly appreciated ... Thankthhh.. !
yes, when lowering these cars you will increase camber and wear out the inside of your tyres. the only thing you can do is raise the car to lower the camber, or buy some sort of aftermarket adjustment such as an SS Kit or adjustable arms.
the wheel shake is a whole other topic in itself, and has a large thread on these forums. could be a number of things including alignment, wheel balance, bushings, and steering pretensioner just to name a few
Thnx for the Reply dude !
soo.. what exactly does the Aftermarket SS kit.. do !?!?! or allows us to do ?!?!
im so desperate to solve this problem !
well about the wheel shake..im very sure its not the wheel balance ... but yea ill search.. on the forums more i guess.. !
SS kit !?!? umm.. how easy is it to install .. ?!?!
again.. what is its function exactly !?!?
Thnx for the reply.. its highly appreciated !
i think there is a topic a few links down in this section, about the EXACT performance SS kit. all the details are in there.
its basically a metal L-shaped block you install which effectively lowers your car about 20-25mm and has a couple of different offset holes in it. so your car sits lower 25mm lower with it so you can raise your coilovers that much and it will still sit the same height as before, and by choosing between the 3 offset holes you can adjust your camber outwards even further.
