How did you losen the bolt on the shock???
Old 06-16-08, 07:22 AM
EuroLex
EuroLex's Avatar
Default How did you losen the bolt on the shock???
Hello! I am installing tanabe springs on my GS. I have done the rear, no problems. But in the front the lower shockbolt is impossible to losen and there´s no space to use bigger/longer tools. What tool did you use when you changed springs on your GS?
Pictures on tools would be nice (don´t know the name of the tools on english) and detailed description.
Old 06-16-08, 07:47 AM
Euphoric
Euphoric's Avatar
I just used a socket, a breaker bar and brute force.
Old 06-16-08, 07:51 AM
rra640
rra640's Avatar
If you can, lay on your back and push slowly on the wrench with the bottom of your foot. Make sure you have good solid jackstands supporing the car when you do this.
Also, spray it with some penetrating lube or WD-40.
Old 06-16-08, 08:03 AM
GSteg
GSteg's Avatar
Just. Make sure its well lubricated and then use a good amount of force! Breaker bar is your best friend.
Old 06-16-08, 10:32 AM
denut-L
denut-L's Avatar
I jacked up both sides and support the car with jackstands then took off the sway bar to get it out of the way of the shock bolt...So much more room to play with... Good luck.
Old 06-16-08, 12:17 PM
EuroLex
EuroLex's Avatar
Is it enough to losen the screws marked 1 och 2 on my picture?
Attached Thumbnails How did you losen the bolt on the shock???-p1020683gs.jpg
Old 06-16-08, 01:29 PM
JeffTsai
JeffTsai's Avatar
Removing those two bolts on both sides will allow the sway bar to hang down out of the way. I used a breaker bar to remove the strut bolt. Or if that's not enough, put a 5ft steel pipe over the breaker bar to give you several times more torque.
Old 06-16-08, 09:12 PM
denut-L
denut-L's Avatar
Yes like jefftsai said removing these bolts will make the sway bar hang out of the way...making life soooo much easier.
Old 06-16-08, 10:20 PM
EuroLex
EuroLex's Avatar
Thank you very much everybody!!! Will go down to the garage now and finish the installation.
Old 06-24-08, 07:03 AM
EuroLex
EuroLex's Avatar
Ok so I finished the passengerside and now I only got one spring to go. But I ran in to some toruble, so I have to ask a (stupid) question. In wich direction should I pull the bolt on the driverside lower shockbolt, that is the bolt facing forward. I pulled it clockwise, right or wrong?
Old 06-24-08, 07:41 AM
Euphoric
Euphoric's Avatar
To loosen it's counter-clockwise.
Old 06-24-08, 07:57 AM
EuroLex
EuroLex's Avatar
OK, Thanks!!
dminah21
09-01-18 08:04 AM
98GSOwner
Suspension and Brakes
03-20-18 01:49 PM
SC3coupe
GX - 1st Gen (2004-2009)
09-17-15 11:39 AM
teejnut
02-27-06 07:11 AM
jbjones
05-29-04 07:29 PM
Quick Reply: How did you losen the bolt on the shock???
