Sway bar, Strut, spring installation Q's
i am getting ready to install new front and rear sway bars, springs and struts on my 99 gs 300. i was wondering if there is anything i need to be aware of before i start. also, how long of a process am i looking at, i have experience lowering cars, but have never done a swar bar. thanks for the help.
sways take a good hour and half drive way job.
difficulty: beginner.
the only tip i can give is make sure ur on level ground and use jack stands if you dont have jack stands try to get the jacks to be the same height. if there not the same then they're will be stress on the screws that hold the sway in place. which will be hard to take off and to put back on. i would recommend using jack stands because u will be under the car for a while.
