Rattling noise from my new teins...
Ok I've searced all over and didnt find an exact answer...I just installed the tein super street coilovers on my car... I bought them brand new. After installing them I noticed it rattles bad in the back just curious to know what the cause is, everything has been tightened down. I messed with it earlier today and it sounds like its coming from the top part of the coilover. SOMEO
NE please HELP!!!
NE please HELP!!!
NE please HELP!!!
NE please HELP!!!
if your currently slammed like i was.. (sitting on bumpstop) pop open the trunk, and place you your weight on the rear bumper. if you bounce the shock, you will notice the outer upper squish donut moves in its cup.... (this is with the main shaft nut max tight!).. it seems like the shaft nut has run out of threads, im gonna remove the rear co's because i forgot to trim the Tein bump stop, and double check to make sure everything is in correct order.
wish me luck
UPDATE
ok figured out what my problem was... it looks like I failed to reinstall the oem bumpstop mounts (gold double sided cup), installed them, trimmed the Tein bump stop, reinstalled and all is good. she rides so much better with the Tein bump stops trimmed!
