Oops...dropped the coilovers too low
When I first installed the coilovers 3 weeks ago I left them at roughly five/four threads, depending on if you count the bottom crap. Well the back is fine but I wanted to drop the front some more. Well I decide to drop down to two threads in the front. When moving the rings about three threads down to two I noticed the spring can wiggle around. It seems normal considering the design but how can I drop another thread of so without having to hold the spring centered until weight is put back on it?
I haven't dropped mines that much so i don't know if the springs move when you try to drop it all the way, i think i'll try tomorrow just for kicks before i get my alignment...
I had my brother in law do them at his shop. Took him maybe two hours total. I paid him $300 for his time. If you are interested let me know. Although I had them installed in Mobile and not Auburn.
Can the spring be rotated or does it need to stay in a certain position. I think I may have rotated it from where it came factory. If lowering it below two threads and having the spring wiggle around, does it not matter that there is roughly 1/4 inch of play and to hold it center is while it being lowered lowered? Basically... Im freaking out because I want to go lower and I want to make 200% sure.
Also, if the spring is able to flop around that would mean that I am riding more on the shock than I am on the spring right? I know when the weight is put on it it will be sitting on the spring though. If Im set to full stiff on the shock would that essentially "strip" it? What if I hit a big bump or kind of ramp something will the spring move again?
Loose spring at full extension is not a huge deal, as you wont have the car sitting with the shock in that position (unless you've run off the road and have your car laying on its side, at which point you have some other more serious problems!)
The spring clocking position is also for the most part irrelevant, as it is a straight spring, with a square seat.
The springs will slide down and sit in place properly pretty much automatically. If you look there is a sort of bevel on the way towards the seat area. They will center themselves. if they don't, the worst is they will slightly catch on the bevel lip, but then slip off and go back into place anyways. In some cases you will hear this sort of loudly slip off and into place once you get most of the weight on them, but this is nothing to be alarmed about. A scary bang or smack noise, but no big deal.
I actually like to drop the car down with the jack a little on the fast side so they sit down properly in one burst, instead of getting hung up (as when you let it down really slowly).
Hope this helps, let me know if you have more questions!
TM Engineering
TM Engineering
yeah i've get a smackin noise in my front coilovers if i hit a bump or if the spring doesnt sit correctly, but the spring rotates when theirs no force to hold them up when the coilovers setted as low as it goes, but once the car is sittin on the floor once u drive the springs should fall back in place. only time would they shift is if u hit a craz pot hole and have ur car bounce higher then the length of that tiny spring. shouldn't be a problem but if u go that low ehh i would worry bout other things like the exhaust and oil paint crossmember.
getfunky
Suspension and Brakes
36
05-22-12 01:23 PM
