how to change rear brake rotors?
Old 12-10-04, 01:53 AM
ILOVEGIRLS
ILOVEGIRLS's Avatar
Default how to change rear brake rotors?
how do i change out the rear brake rotors? i found how to do the fronts but nothing on the rear. thanks its a gs300.
Old 12-10-04, 12:08 PM
Eliel
Eliel's Avatar
Hey man, this is how I done it before. Take the caliper & pads off (make sure the emergency brake is not in use). You'll need a pully that you can find at the autopart store. The tool has a main center bolt & a grove on eather side for 2 smaller bolts. These will get screwed into the the disk (which it has 2 threaded holes). After securing the pully, spray wd-4 on center hub, start to turn the center bolt as you hit (not to hard) the center of the disk w/ a hammer. The vibration of the hammer will help the disk to get loose from the center hub. The disk should come loose after that. Hope this help.
Fpan87
RX - 3rd Gen (2010-2015)
02-21-18 10:28 AM
shaft
11-15-13 01:10 PM
ScottGS300
Suspension and Brakes
06-02-10 07:15 AM
rerose
05-02-06 07:00 PM
disc108
Maintenance
01-21-03 09:56 PM
Quick Reply: how to change rear brake rotors?
