alignment question
alignment question
i'm riding on stock 17" with stock bridgestones. prior to my alignment, my car pulled to the right.
after my alignment, it pull to the right still, but very slight. ie, on the freeway for about a 1/4 mile it will go straight then it will start to veer toward the right. i'm not fighting the steering.
is this correct? anyone have the same thing happen to them. i'm not sure if i should take it back and have them check it out again or this is normal.
if you need the specs of the alignment, i can write the numbers down.
thanks
thanks
Try a tire rotation and see if that helps. I assume the tire pressures were already checked and that is not the cause? Also, as mentioned, make sure it is not the specific road you're driving on causing the pull.
No, pulling in either direction is not normal- but there are a number of reasons why it might be happening and you should determine what is causing it.
