2003 Gs430 issue after timing belt kit done.
I have a 2003 gh430 with 109,411 miles. I bought the aisin timg belt kit. Replaced the timing belt, drive belt, water pump & gasket, o-rings,thermostat & gasket, camshaft seals, idler 1 & 2, hydraulic tensioner, NGK IX Iridium spark plugs, covers for the pedals except gas pedal cause it was to long. Now the vsc light & check engine light is on.
Disconnect battery for 30 min and then reconnect.
ANYTIME you see VSC/Check Engine light on and don't have a clear reason why, force it to be cleared. Seen it too many times set for no legit reason.
I did my timing belt and got the drivers side (left) cam off by 1 tooth and didn't realize it till I started it. It came up with a code, but no VSC/CE light. I had to go back in and fix, not a real big deal.
Hopefully all is ok, should be.
suprababy (07-16-17)
boatable
06-03-15 11:24 AM
BDSL
06-02-12 03:14 PM
