ISF headlight went bad..
Old 03-23-17, 06:22 PM
jcunc05
jcunc05's Avatar
Default ISF headlight went bad..
Curious if any others have had issues with their HID lights on their 08 or any other year really? I have a 08 with 80k.
Old 03-23-17, 07:50 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,079 Likes on 2,472 Posts
OEM bulbs die. It's common. I replaced mine with Philips bulbs and never looked back. Been working like magic.
Symptoms: Turn on lights, both light up, then soon after one goes dark. Turn lights off and on quickly, both lights good again, then one goes out. Pretty typical when one bulb decides to go on welfare instead of working for a living.
Old 03-23-17, 08:49 PM
DBrian
DBrian's Avatar
I just had this on my 2012 with just 42k miles so yes I too was disappointed. I checked the dealer and they wanted something in three figures $ to fix it. I hadn't done it on this car before so I found a good YouTube on bulb replacement, bought a Toyota OEM bulb on eBay for about $28, and did it myself in about a half hour. I'd say the hardest part is carefully removing those little plastic clips on all the engine cover parts.
also i guess you have to be careful of the number of lumens of the bulb you buy if you just do one, or you can end up with one bulb a slightly different color temperature than the other one.
Old 03-23-17, 08:59 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Originally Posted by DBrian
...I'd say the hardest part is carefully removing those little plastic clips on all the engine cover parts.
Go to eBay or Clipsnfasteners .com and buy a bag of clips - 25 for less than $10 - and pitch the ones that are a PITA to remove. They love to break.
Buy two bulbs - you are dead on the money - they will look different because HIDs "burn in" and they will never look the same if you just replace one.
Old 03-24-17, 07:17 AM
DBrian
DBrian's Avatar
Thx Lobux, yeah I was thinking of just buying a bulk quantity of those clips. I did one headlight bulb and I was pretty careful to look for the OEM part #, but the new bulb is a slightly cooler temperature (a bit more blue) than the old one. Does $28 sound about right for that bulb on eBay?
Old 03-24-17, 08:46 AM
MisterSkiz
MisterSkiz's Avatar
Yes, the headlight in my 08 IS-F started flickering last year around 60k miles.
I bought two new bulbs and was surprised at how brighter and whiter than the original OEM bulbs.
I bought mine from Amazon link below:
Amazon Amazon
When you get them, you can verify that they are indeed legit Phillips bulbs as well on Philillps site.
Look up headlight replacement on the forum, as if I remember I had to remove the air box and pull out the wiper fluid fill tube, it was pretty easy.
Old 03-24-17, 09:30 AM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
https://www.amazon.com/gp/product/B00480J4I2/
Those are the exact same bulbs I got from the same Amazon vendor. Replaced both at the same time to prevent one appearing more blue than the other - also, when one goes, the other isn't far behind. I remember them being a bit cheaper before, but under $50 is a good deal for genuine Philips bulbs. The eBay bulbs at $28 might very well be counterfeit. There is (unfortunately) a lot of that going on these days - just look at our spark plug thread to see just how bad that is...
Old 03-24-17, 12:44 PM
F_Throttle
F_Throttle's Avatar
Has anyone upgraded their HIDs to a 55watt kit?
Old 03-24-17, 01:00 PM
MisterSkiz
MisterSkiz's Avatar
I have not, but if you do, make sure to use a relay kit....do not wire it directly to your current OEM ballast power wires.
Old 03-24-17, 02:22 PM
jdmSW20
jdmSW20's Avatar
yeah like said above the bulbs do eventually die, they don't last forever. I just had my driver side go out about 2 weeks ago. I got new 5k bulbs(since they didn't offer 4300k) for low beams and 3k hid kit for the fogs from xenondepot and been good every since, I did the same ones on my old IS350 and my old LS400
Old 03-24-17, 07:38 PM
jcunc05
jcunc05's Avatar
Default thanks
Thanks for the feedback gentlemen.
Dukenukemx
02-20-15 01:43 PM
Nickv
RX - 1st Gen (1999-2003)
10-29-13 03:43 PM
Jstunner56
12-07-09 11:39 PM
OutkastGS3
08-25-08 09:37 AM
chnco
12-06-07 11:54 AM
Quick Reply: ISF headlight went bad..
