Resonator delete...what of the secondary cat delete too?
Old 03-21-17, 07:45 PM
GetKinetic
GetKinetic's Avatar
Default Resonator delete...what of the secondary cat delete too?
So I was quoted by two local exhaust shops $200 to cut out/delete the resonator and weld in pipes, but that didnt include Stainless exhaust 2.5" pipes. It would be non stainless metal. If I want stainless I have to source it myself.
wow. Why so much?!?
second question. Does the RCF have a pair of secondary cars/converters just passed the o2 sensors in the mid pipe?
why arent we deleting that 2nd cat as well?
leaving only the primary cats located pre midpipe connection?
thanks in advance for edjemicating me
Old 03-21-17, 10:36 PM
lexusrus
lexusrus's Avatar
I'm on the fence about deleting the resonators also.
Does anyone know if the OEM pipes are stainless steel?
Where can I buy a stainless "bolt on pipe" to replace the resonators so that I can EASILY reverse it when I need to?
Thanks
wow. Why so much?!?
why are qe deleting those too?
Old 03-22-17, 12:47 PM
GetKinetic
GetKinetic's Avatar
The last shop I was at said the stockpipe is stainless.
to go bolt on you would need to replace the entire midpipe.
that would delete the secondary cat, o2 sensors and the resonator.
Old 03-22-17, 01:08 PM
Davew77
Davew77's Avatar
Here is a undershot of my car with the stock pipes when it was having the Meisterschaft installed. If the exhaust is stainless steel then it's most likely 409 series. (I can't find any hard specs on it).
Here is the 304 stainless steel Meisterschaft exhaust:
It still looks the same as the day it was installed.
I know that the Meisterschaft is 304 stainless steel, which is very corrosion resistant. But from what I gather a lot of stock exhausts which use stainless steel choose to use 409 stainless steel (it's not as corrosion resistant). If I did source my own stainless steel pipes I would pick up 409 stainless pipes to match the stock grade (it likely is 409 if it's stainless).
Thanks
The only cost effective way to do a bolt on resonator replacement is to replace the entire midpipe.
But you can keep your resonators after they are cut out and have them welded back in later just like they welded in the pipe to replace the resonators when they cut them out.
Old 03-22-17, 02:26 PM
flowrider
flowrider's Avatar
Received 1,829 Likes on 1,291 Posts
To the OP, I am mystified that you can not find an exhaust shop with SS exhaust system piping. And $200 to R&R the resonators is ridiculous
Lou
GetKinetic (03-23-17)
Old 03-22-17, 02:56 PM
GetKinetic
GetKinetic's Avatar
Lou
A Greed.....
Old 03-23-17, 06:04 AM
lexusrus
lexusrus's Avatar
Thanks for the information.
You stainless pipes look amazing. I guess it is still true if you want to play you gotta pay.
Old 03-23-17, 06:06 AM
lexusrus
lexusrus's Avatar
I'm thinking going for the Borla system?
Old 03-23-17, 06:21 AM
cosmo1
cosmo1's Avatar
Get the secondary's cut is perfect with noise and no codes. I did that with a Tanabe Axleback and it sounds great..
Old 03-23-17, 07:02 PM
GetKinetic
GetKinetic's Avatar
this is what I was looking for.
someone who deleted the Resonator and 2nd cats and likes it
Old 03-23-17, 07:03 PM
GetKinetic
GetKinetic's Avatar
ou happen to have a picture of your mid pipe with the 2 deletes?
Old 03-24-17, 03:11 PM
JB5674
JB5674's Avatar
The borla system has just pipe for the mid section ( no res and no secondary cat )
GetKinetic (03-24-17)
Old 03-24-17, 06:49 PM
Davew77
Davew77's Avatar
I've never had an exhaust that felt as solidly built as this one. I'm a firm believer in getting what you pay for (most of the time). I have no regrets for what I paid for it. I've never thought for a second that I should have gotten a cheaper one.
Old 03-25-17, 12:14 PM
joeyz10
joeyz10's Avatar
Still torn between Borla cat back and just a resonator delete. With the delete the Exhaust tips looks original yet louder and that is what I am leaning towards. Any suggestions?.
Old 03-25-17, 12:31 PM
GetKinetic
GetKinetic's Avatar
im right there too. If I can get the delete cost to under $150 ill do that first and then see if I need to progress to a borla later.
jivoz123
Performance
06-20-23 11:00 PM
F_Throttle
IS F (2008-2014)
11-12-14 07:25 PM
RCM83
IS F (2008-2014)
19
12-29-13 04:51 PM
NickawdIs
Performance
28
01-07-13 01:00 PM
Confusion
20
01-21-10 09:12 AM
Quick Reply: Resonator delete...what of the secondary cat delete too?
