Please help! Already bought new transmission 2001
Old 02-26-17, 09:20 PM
rubeld
rubeld's Avatar
Default Please help! Already bought new transmission 2001
Hey guys, so I was having issues with my trans and was able to source a good one with low miles along with torque converter. I ended up replacing both torque converter and transmission. Filled with brand new type tiv. Started it up, shifts through all gears perfect but doesn't move at all. Feels like it's not even engaging. Reverse lights come on and everything. Idle fluctuates when I shift. Just does not move at all. Replaced with brand new battery also. Please help guys! 2001 ls430
Old 02-27-17, 01:29 PM
rubeld
rubeld's Avatar
Someone posted 2 great printouts of fuses to check for my ls430 transmission. I'm trying to figure out where the post went? Idk how it's just not there now
Old 02-27-17, 07:20 PM
911LE
911LE's Avatar
Did you remember to reconnect the driveshaft?
Old 02-27-17, 08:18 PM
2KHarrier
2KHarrier's Avatar
Yeah, RKW77080 posted a few diagrams, but they're gone. Maybe he's looking for better info to post???
Old 02-28-17, 04:15 AM
rkw77080
rkw77080's Avatar
Check driveshaft first, of course...
Here are all the transmission related fuses you should check.
Old 02-28-17, 07:08 AM
LEXUSC-400
LEXUSC-400's Avatar
Have you double checked the trans fluid? Now that you have ran it through the gears double check the trans fluid level, I've seen this happen before where the level looks good just after installing but after first start up it works a lot of air out and the trans is so low on fluid it won't move.
Old 02-28-17, 02:37 PM
rubeld
rubeld's Avatar
You sir are a saint. Thank you so much. Gonna try these tonight will check back in tonight! Thank you guys! Yes double checked fluid. Driveshaft bolted up
Old 03-01-17, 03:36 PM
rubeld
rubeld's Avatar
Hey guys so I checked all fuses and connections again everything looks good. Im really confused could the torque convert possibly be an issue somehow? That's what my buddy keeps telling me. Also, when I put into reverse while cold the RPMs go up rather than drop down like they used to. Please help guys thank you!
Old 03-01-17, 03:50 PM
911LE
911LE's Avatar
I don't see the torque converter being your problem unless you forgot to bolt it to the flexplate. Did it have fluid in it when you installed it? Was it fully seated on the transmission to where you had to slide it towards the engine to install the bolts? Even if the converter itself was bad the car should still move at least a little bit.
Have you tried giving the engine some throttle while in gear to see if it will move at all? There could be air pockets in the trans or converter.
Did you double check to make sure the shifter is hooked up correctly on the trans? It may be falling in between detents and not really in a gear.
Old 03-01-17, 03:58 PM
rkw77080
rkw77080's Avatar
Now that we've ruled out "electrical" as your culprit, here's what the repair manual says about possible "mechanical" issues...
File Type: pdf
Old 03-01-17, 04:01 PM
rubeld
rubeld's Avatar
thanks 911LE for the insight. Yea so there is paint marks on the torque converter and the flex plate that help you align it correctly. It all sat flush and bolted together perfectly. Yes i let it all get to operating temp and put in gear and give it gas and nothing. I went under while a buddy went through the gears and I could see it all moving how it's supposed to. Could one of the sensors have gone bad? Im at a complete loss with this.
Old 03-01-17, 05:01 PM
rkw77080
rkw77080's Avatar
If you have a bad sensor, you will be a DTC. Are you getting any DTCs?
File Type: pdf
Old 03-01-17, 05:47 PM
rkw77080
rkw77080's Avatar
Also take a look at the attached transmission related documents...
File Type: pdf
File Type: pdf
Old 03-02-17, 12:19 PM
911LE
911LE's Avatar
What kind of issues were you having with the original transmission? How many miles did it have?
Old 03-02-17, 06:51 PM
rubeld
rubeld's Avatar
i had 240k on the other one. It would take a long time to go into gear when cold I would have to give it gas for it to finally bang into gear in reverse or drive. Until one day it got too bad even when warm to the point I couldn't drive it anymore. I had no check engine light. I did not check the codes though.
Quick Reply: Please help! Already bought new transmission 2001
