Question about throttle body cleaning
Old 02-22-17, 08:12 PM
Mrfouche
Mrfouche's Avatar
Exclamation Question about throttle body cleaning
My question is if i take out the throttle body to clean it will i have to reprogram it?
Old 02-22-17, 10:28 PM
Aspect
Aspect's Avatar
Don't think you have to "reprogram" it of any sort. IIRC, I've read up on spark plug changes for the IS250 which require it to be removed and reinstalled afterwards with no mention of reprogramming like you describe. If you are going to clean it, I think you have to be careful not to manually move the throttle body plate.
Old 02-22-17, 11:27 PM
whitebeast
whitebeast's Avatar
you don't have to reprogram the throttle body after removed to clean it.
Old 02-23-17, 05:30 AM
See5
See5's Avatar
I did mine, no programming.
Old 02-23-17, 05:31 PM
Gville350
Gville350's Avatar
Just be careful when cleaning the inside on either side of the butterfly. These electronic motor'd TBs now are sensitive and have plastic gears.
Old 02-23-17, 06:55 PM
Mrfix
Mrfix's Avatar
Disconnect your battery before you take it off.
Old 02-24-17, 01:14 AM
See5
See5's Avatar
I actually removed it so that I don't get carbon inside the manifold/engine. And boy, there was excessive build-up. I don't know if my Intake was a reason for that.
Old 02-24-17, 04:44 PM
Gville350
Gville350's Avatar
If it is that bad, you might want to consider a catch can.
Lukas99GS
12-24-13 05:29 PM
Rock-a-Lex
Performance
18
01-26-10 04:42 PM
Stage3
Maintenance
01-08-08 07:05 PM
tmf2004
Performance
08-24-05 07:31 PM
Zoso
05-16-02 04:40 AM
Quick Reply: Question about throttle body cleaning
