Disable the Beeper
Disable the Beeper
I've asked this before but it was buried within another thread so I'm going to try again...
Anyone know how to disable the beeper for the automatic rear door? I'd settle for just flashing lights but the beeper's a little too loud/annoying.
I thought I read it could be disabled via c-best.
I agree with the annoying beep. My wife says it sounds like the garbage truck has arrived.
I was just in for the 1K sevice and the service tech says it is a safety feature and cannot be disabled.
However, on page 38 of the owners manual is says that it can be disabled and to ask your Lexus Dealer about it. So I have a call in to them now. Will let you know what i learn.
John
just talked to Lexus service rep today...
they expect c-best program at the end of this month inorder to disable. Page 38 of owner's manual says that it can be disabled. Service coordinator said that it if it is in the manual then it will be able to be done.
Just picked my car up after 1K mile service and here's what they told me. Even though the manual says the beep can be disabled the current C-Best software only allows for three settings: 2 beeps, 5 beeps, and 8 beeps. There is no "disable" setting. I had my service techs change it to the lowest setting: 2 beeps - so now basically when I hold the button down on my remote it beeps once, then the hatch begins to open, it quickly beeps again as the hatch begins to raise and that's IT. It ain't perfect but it's MUCH better. My svc mgr says they will take this up with corporate to find out WHY the owner's manual states the beep may be disabled - if they're NOT given the proper software to execute it. Maybe by my 5K service they'll have a solution - I'll keep y'all posted
FINAL ANSWER
spoke with my service manager today - he had finally received an answer from Lexus corporate - and he told me that the way mine is set now is considered "disabled" he says the manual is misleading and that corporate is considering re-wording that paragraph in future editions.
In reference to what I explained prior - when the button is pressed the vehicle emits 2 short beeps - like when you lock or unlock your car - then that's it, no more beeps while the rear hatch opens and closes. So no matter which C-Best setting you'll always get 2 initial beeps, then beep settings can be made for an additional 2, 5, or 8 beeps after that.
does that make sense - I hope I explained that clearly
rubyredes
ES - 5th Gen (2007-2012)
06-29-07 08:04 AM
