Lexus Vehicles Classifieds Lexus Vehicles for sale by members, no dealers or vendor posts allowed. Only active members with >100 posts may post non-Lexus vehicles.
CO Sc300 2jzgte v160
Old 01-26-17, 11:56 AM
mikef
mikef's Avatar
Default Scupra 2JZGTE new v160 1993 sc300
This is a fine example of an amazing sports coupe, everything was done to spec, Never been raced or seen snow. The car lived most of its life in Florida, now in Denver, The CarFax is clean. Emissions passed.
My vision was to try to stay with OEM Toyota parts as much as possible, as you can see the Majority is all new OEM parts.
New v160 and a massive list all new toyota parts ordered direct from Toyota
This is a 190+mph car that is ready to make some serious power
please only contact me if you're a serious buyer, 954-638-3900, Mike
$24,000
2JZ GTE V160 Parts List
6-speed drive belt tensioner
16620-46070 tensioner list 243.36 cost 182.52
16621-46010 bracket list 50.22 cost 37.66
16622-46010 arm list 23.96 cost 17.97
16602-46010 shock absorber list 77.66 cost 58.24
91511-g0845 bolt list 1.24 cost .93 x 2
90901-16001 stud list 2.79 cost 2.09
90179-08171 nut list 1.21 cost .91 x 2
90116-08348 stud list 1.15 cost .86 x 3
90080-17242 nut list 1.78 cost 1.33 ex x 2
Transmission
33030-0w212 v160 assy new $6300
31123-14020 inspection cover cost 30.38
31121-14030 inspection cover cost 36.65
90080-11228 bolt cost 3.28 total x 4
08885-01306 v160 oil qt cost ea x 2 Check to see if its prefilled/ checked ok
57255-14231 CROSS MEMBER, cost 173.23
90980-11051 Toyota HOUSING, CONNECTOR F cost 5.19
82998-12440 terminal for the housing connectorsx2
58261-14010 upper trans tunnel cost 80.33
90159-A0045 Screw, W/washer 2.92
12371-46110 trans mount list 87.92 cost 65.94
Shifter
33504-14130 shift **** cost 92.08
33511-14031 control shaft cost 25.86
33513-22030 yoke cost 7.87
33530-14442 93.5-95 short throw shifter cost 133.56
90301-11015 o ring cost 12.16 total x 4
33531-14010 boot cost 40.42
90387-08134 collar cost 4.22 total x 2
33555-14110 boot cost 38.38
33555-14100 boot cost 10.17
33556-14050 seat cost 1.63
33057-14010 bracket cost 45.94
33570-14070 shifter tri-pod cost 97.65
93381-16016 bolt cost 3.04 total x 4
90179-08095 nut cost 2.46 total x 2
90105-08200 bolt cost 2.06 total x 2
91651-60835 bolt cost 6.08 total x 4
90105-08076 bolt cost .79
90179-08233 nut cost 1.03
90250-06026 pin cost 1.18
90467-21010 clip cost 2.46
33546-22020 bushing cost 29.00 ea x 2
Clutch parts/pedals
SC300/SC400 5 speed conversion pedal set $355
58280-14080 boot/plate assy list 25.72 cost 24.33
SC300 Manual Shifter Boot $58
31470-14060 slave cylinder list 83.38 cost 62.53
90080-10055 bolt list 1.21 cost .91 x 2
31410-14310 master cylinder list 150.31 cost 112.73
90179-08237 nut list 1.24 cost .93 ea x 2
31481-14260 tube list 32.07 cost 24.05
96816-50335 hose list 31.09 cost 23.32
31484-24010 bracket list 8.48 cost 6.36
31482-14060 tube list 15.00 cost 11.25
90119-06406 bolt list 1.01 cost .76
96991-10080 clip list 1.58 cost 1.18 ea x 2
90119-06733 bolt list .95 cost .71
00475-1BF03 brake fluid pint list 5.81 cost 4.36 ea x 2
90363-12002-77 BEARING,PILOT LIST 8.65 COST 6.49
96152-00500 RING, SNAP LIST 3.36 COST 2.52
90903-63001 BEARING , RELEASE LIST 81.00 COST 60.75
90560-50001 SPACER LIST 7.36 COST 5.52
90560-79001 SPACER LIST 3.02 COST 2.26
90206-12006 WASHER, LIST 2.01 COST 1.51
90520-75001 RING, SNAP LIST 3.74 COST 2.80
31264-14060 SPRING, LIST 3.74 COST 2.80
31231-14050 HUB, LIST 44.28 COST 33.21
31204-14060 FORK LIST 88.70 COST 66.52
90119-08079 BOLT, COVER LIST 0.75 COST 0.56 EA X 6
90910-02115 BOLT FW LIST 12.18 COST 9.13 EA X 8
13450-0W011 FLYWHEEL LIST 831.35 COST 623.51
31210-14170-84 REMAN COVER LIST 174.02 COST 139.61 [ includes 7.00 core charge ]
steering reservoir. 44360-24042
ClutchMasters 16000-HD00-R FX100 Stage 1 Clutch Kit Toyota Supra $660
RPS Cyn-R-G Aluminum Segmented Flywheel for 1993-98 Supra TT BF-22170 $474.05
Rear Differential/Driveshaft/Axles
220mm Diff JDM 3.26 LSD supra $1500
Custom driveshaft $375
Rubber rear driveshaft coupling from supra TT 37511-30020 COUPLING, FLEXIBLE cost $307.06 price $228.72
42340-14140 lh drive axle list 568.87 cost 426.65
42330-24030 SHAFT ASSY, RR DRIVE cost $437.10 price $325.58
Oil pressure sensor mod / Gauges
90401-19008 union bolt $33
90430-20016 Gasket $1.28
90301-68005 O-ring $3.67
VDO-360086 Sender press 100PSI 1/8 $32.29
VDO-350106 Gauge press 100PSI CV $44.99
VDO-150121 Gauge Turbo Mech 30HG-25 $59.99
Auto Meter 3222 Nylon Tubing$6.72
1/8 NPT TO 1/8 BSPT $11.21
T-FITTING ADAPTER FOR BOOST GAUGES POWERSTROKE MAP LINE BOOST LINE 1/8NPT DIESEL
VDO-150851
Fuel Pump
Walbro 255 in tank fuel pump with setup kit $100 plus ECU fuel pump $49
Engine
2JZ GTE supra swap $3930 with cat (came from a Supra clip with less then 15k miles)
CX Blow Off Valve $60
CX Racing Intercooler for 1993-1998 Toyota soaror $494.10
Fan Shroud for supra 92-00 $199.00
MIO-MMRADSUPT Radiator $285.00
Tweakd Performance wire harness $825
97 SC400 cluster $150
JDM down pipe $150
front tow strap $25
Turbosmart TS-0101-1001 $75
Old new stock Floor mats $200
95 Tail lights $150
KW V3 Coilovers $2000
Sc300 $6000
Wheels $1407
LS400/Supra TT rear calipers and goodridge lines and R1 rotors $1250
Full poly bushings, front
Driveshaft shop 1000hp chromoly 3.5 $800
Personally If I were in the market for a supra this would be an option aka a wolf in a sheep. and save 3x the price.
phone number 954-638-3900 Mike
$24,000
mikef is offline
Old 01-27-17, 07:37 AM
SSmith
SSmith's Avatar
The car is actually worth all that to the right person. It's got all that just in mods not counting the car. Problem is, the only guys that can really afford to pay that price all want a Supra instead. I'm in the same boat and I have more mods than this one. I hope he actually sells it though for what he wants.
Shane
SSmith is offline
Old 01-27-17, 07:39 PM
shaky
shaky's Avatar
This car is not for everyone, I have a sc300 vvti gte with single turbo w/ v160, love the combo. I don't think the price is crazy if you add up all the parts and compare to Supra prices right now.
Any 6-speed Supra is in the 35-40k range, hell even some auto tt are in the 30's. OP: Good luck with the sale, looks like a great car, someone will pay close to your asking price.
Biggest issue with the Sc300 is blue book, no one can get a loan, so its cash only sale.
shaky is offline
Old 01-27-17, 10:40 PM
Midengtoy
Midengtoy's Avatar
These itemized prices must be old. With the recent discontinue of Supra parts the prices have skyrocketed, a V160 is at least that much used now. Might be better to part out and then sell the car separately because SC's just don't get the same respect as Supras. Very clean and glws.
Midengtoy is offline
Old 01-28-17, 12:49 PM
mikef
mikef's Avatar
Hi guys, the list I have up is what I can show proof of receipts with those prices, I didn't want to adjust to the new market now, everything you see in that list is all new from Toyota except for the diff. The car is so robust and feels so new in a classic way, these are so underrated.
mikef is offline
Old 01-28-17, 04:51 PM
Piraiba
Piraiba's Avatar
Hopefully it goes to a good home. glws!
Piraiba is offline
Old 02-03-17, 04:39 PM
mikef
mikef's Avatar
Come check this beauty guys
mikef is offline
Old 02-04-17, 07:00 AM
jimmymac30
jimmymac30's Avatar
Mike, your car is stunning. I'm gonna ask my wife if I can take some of the savings and come pick this up from you lol
this is a super clean example of a proper sc300 build!
jimmymac30 is offline
Old 02-05-17, 09:07 AM
97-SC300
97-SC300's Avatar
Yeah I would buy it as well but we have way too many cars as is and not being able to drive half of them half the year in IL, it's not an option for us at the moment.
But you're definitely going to be hard pressed to find a cleaner SC than this thing. Easily one of the top 3 cleanest one's I've ever seen.
97-SC300 is offline
Old 02-15-17, 12:36 PM
mikef
mikef's Avatar
Still available, have some interest local, and some out of state.
mikef is offline
Old 02-16-17, 05:02 PM
mteele
mteele's Avatar
I probably should have just bought this instead of building my own. Great deal!
mteele is offline
Old 02-18-17, 07:31 PM
sidwin
sidwin's Avatar
what's the asking price? did i miss it?
sidwin is offline
Old 02-26-17, 06:33 AM
mikef
mikef's Avatar
Mid 20s, your welcome to throw your best offer.
mikef is offline
Old 03-06-17, 03:14 PM
sfearing
sfearing's Avatar
You've built my dream car - great job!
sfearing is offline
Old 03-10-17, 02:12 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,312 Likes on 1,410 Posts
Mike, please post an asking price per our rules
DaveGS4 is offline
Quick Reply: CO Sc300 2jzgte v160
