engine and vsc lights on
Old 01-22-17, 10:40 PM
sy02
sy02's Avatar
Default engine and vsc lights on
today my engine and vsc lights on I don't know why or because its raining and drove in the flood and something got wet.
Old 01-22-17, 11:34 PM
isfvss
isfvss's Avatar
YOU WHAT how deep????
Old 01-23-17, 12:24 AM
hamooduae
hamooduae's Avatar
it happened to me , something it was rainy , i drove with water approx above tire , i got CEL , reset it ..
everything was fine .
Old 01-23-17, 01:21 AM
nks979
nks979's Avatar
How deep was this water you drove through? I would think if you got water in the engine it would shutdown on you immediately but you never know.
Old 01-23-17, 06:05 AM
Eminence
Eminence's Avatar
A CEL with VSC light on indicates the car has gone into limp mode. It could be a hiccup but pull the code and see what comes up. Limp mode or safe mode is usually triggered by events that the ecu deemed to be serious in nature to prevent catastrophic engine failure.
The flood water may have gotten into some connectors and caused a brief short. Things like a misfire, MAF sensor damage, etc will put the car in limp mode.
My suggestion...if the car operates fine. Pull the code, reset and let the car/ecu cycle through a few trips and see if the problem comes back up.
Old 01-23-17, 09:08 AM
Joker4096
Joker4096's Avatar
Pulling the code is the only way to truly understand what is happening and why. the secondary o2 sensors could have gotten wet and are failing, gas cap possibly not sealing, the possibilities are endless. Pull the code.
Old 01-23-17, 01:35 PM
mindcrime
mindcrime's Avatar
same thing just happened to me LOL. where's the OBD II port? i'll pull the code with my SCT tuner
Old 01-23-17, 01:40 PM
Joker4096
Joker4096's Avatar
under dash kick panel straight up from where your feet are.
Old 01-23-17, 01:47 PM
mindcrime
mindcrime's Avatar
​​​​​​​thanks.
Old 01-23-17, 02:28 PM
mindcrime
mindcrime's Avatar
read this
​​​​​​​ https://www.clublexus.com/forums/is-...g-the-ecu.html
sy02 (01-23-17)
Old 01-23-17, 02:30 PM
mindcrime
mindcrime's Avatar
I pulled code P0402. i'll research what it is. just pulled fuses and we'll report back once i ECU is reset
Old 01-23-17, 03:03 PM
mindcrime
mindcrime's Avatar
reset successful, but hope that code doesn't ever come back
Old 01-23-17, 11:31 PM
sy02
sy02's Avatar
the flood is only very low just on the tire. How do you reset the code/what kind of code. tnx all who replied
Old 01-23-17, 11:57 PM
sy02
sy02's Avatar
Just saw the link, tnx
Old 01-24-17, 12:05 AM
sy02
sy02's Avatar
sorry not really a flood, just water filing up on the streets maybe got wet under something in the engine. I just saw the link might do it tomorrowto pull the 2 fuses.
Quick Reply: engine and vsc lights on
