Corner Light Bulb NIKE shape Suggestion
Old 12-08-16, 05:13 PM
bossrek
bossrek's Avatar
Lightbulb Corner Light Bulb NIKE shape Suggestion
Hi
I want to share your experience with using led light instead of the bulb
I just purchased Lexus LS460 2007 with 93000ml
I noticed the corner lights not working at all in the day light mode or at night i checked no any light coming from this corner although it is not showing any warring light in the dashboard
I have found these lights in the auto zone can you please help me to chose the right one which will not cause any damage the headlight body because of the excessive heat
thank you
Old 12-08-16, 10:18 PM
CRowe14
CRowe14's Avatar
For the "Nike" light, technically, the park light, none of those bulbs will work, as they are all too large.
The default/OEM size is 194.
I as well as a few others, particularly Shibumi1 would love to assist, but I would first recommend taking your time to read through this thread, as it has a tremendous amount of GREAT information in it!
https://www.clublexus.com/forums/ls-...bulb-swap.html
I should also mention that he sticky on the top of the page(which is where this link was found) is LOADED with a sunning amount of information regarding the LS 460.
Any questions, feel free to shout!
Old 12-09-16, 09:29 AM
GR6RR
GR6RR's Avatar
those in your hand are too large
Old 12-11-16, 06:58 AM
sktn77a
sktn77a's Avatar
Are you talking about the very corner lights, outside the headlight washers, or the section of the "nike" inside the headlight washers? Mine are lit in the inside but not the outside. I thought that was normal(?)
Old 12-26-16, 09:48 AM
bossrek
bossrek's Avatar
have purchased this set as been advised from the members
and the results are
snakehead (02-01-24)
Old 12-26-16, 10:59 AM
CRowe14
CRowe14's Avatar
These look excellent man, awesome job!!!
How did the mod go over all for you, did you find it difficult?
The light emission looks great!
Old 12-28-16, 10:11 PM
bossrek
bossrek's Avatar
hi
i did it step by step as explained by other members
the only difficult a faced that the second light fell off between the radiator support and frame it took around 30 min to get it out and ended up with many scratches and blood came out from my hand and fingers to get the small light out
melymel96
01-13-17 07:22 AM
Duff
01-25-15 05:53 PM
audiohouse
08-13-13 02:06 PM
Fjaw
02-03-11 04:14 PM
StylinGS300
12-12-10 07:12 PM
Quick Reply: Corner Light Bulb NIKE shape Suggestion
