LSD for the LS?
Old 11-04-16, 02:35 AM
Scootymad
Scootymad's Avatar
Default LSD for the LS?
What differential did Toyota put in these things? All I know its a peg legged, one tyre fire, single spinning work of art. Are there any LSD heads out of a JZZ30 Soarer/SC300/400, JZX100 Chaser or JZA80 Supra that will go in the LS housing? The single spinner caught me out this morning when it decided to spin twins and spun me around at 25mph, and made me look like a complete douche looping out a limousine
Old 11-04-16, 04:55 AM
Johnhav430
Johnhav430's Avatar
LOL when I got my 335i I was told limited slip was reserved for M cars. A buddy told me, "Basically, you have 1WD."
Gotta add limited slip to a must have on the next car.
Old 11-05-16, 09:35 PM
airchomper
airchomper's Avatar
Yeah, you can buy a part. Or you can put in a mk.4 supra diff. But I think the supra diff is super expensive and there's one part you have to swap between the two differentials - I think someone in the 2nd gen LS400 forum did it once upon a time.
But the Supra LSD diff has a 3.133 rear end, we have 3.27s in the 01-03 and the 04-06s have 3.62 final drives? You can find out more in this thread.
Old 11-28-16, 08:41 PM
Scootymad
Scootymad's Avatar
There's plenty of Supras down here, factory rear ends shouldn't be too hard to come by, might try swapping out the diff head for a JZA80 Supra item
Old 11-30-16, 10:44 AM
bmore430
bmore430's Avatar
Would be very cool if someone found a way to do this and post up the results.
Old 11-30-16, 08:08 PM
lev00221
lev00221's Avatar
My 1993 LS400 is supercharged and I did not like the "one wheel peel" so I tried to to find an OEM LSD that would fit the original pumpkin. I tried LSDs from MKIII and MKIV Supras, and from an IS300. None of these options would work. I considered having the MKIV Supra pumpkin frankensteined onto my car with custom axles but the labor cost was too high and there was no guarantee that it would work well. I wound up buying a very expensive Cusco LSD that was designed for the car. It has worked out well so far.
Old 11-30-16, 08:37 PM
bmore430
bmore430's Avatar
http://www.frsport.com/Cusco-HBD-193-A-Hybrid-LSD-Lexus-LS430-UCF30_p_198726.html
Old 12-01-16, 05:45 PM
lev00221
lev00221's Avatar
My apologies..... I thought that I was posting in the first gen forum. The Supra LSD will most likely work in the second gen Ls400 and the LS430
99Slicktop (02-04-21)
Old 12-04-16, 01:50 AM
Scootymad
Scootymad's Avatar
Would I just have to fit the diff head or swap the whole housing out? I'd imagine the diff head would be the way to go. Not worried about diff ratios being slightly shorter, the gas mileage is utter rubbish as it is
Old 12-04-16, 08:16 PM
Scootymad
Scootymad's Avatar
Cheers for your input Kitabel. I live in JDM heaven so all of those cars are fairly plentiful here. I might give it a crack, buy a complete unit out of a Supra or Soarer or something and start taking notes of how they fit. Might be able to get away with it I reckon. The LS just sits in the yard anyway so no biggie if its off the road for however long it takes
Old 02-04-21, 07:21 PM
99Slicktop
10th Gear
99Slicktop's Avatar
please any more info on this contact me!!
Old 02-04-21, 08:00 PM
05ls430518
05ls430518's Avatar
The supra diffs do not fit the LS430 I know that for a fact there is no known oem diffs that just bolt in you have to go aftermarket
Old 02-04-21, 08:11 PM
99Slicktop
10th Gear
99Slicktop's Avatar
I was asking for my 1999 ls400
Old 02-06-21, 11:30 PM
CSA
CSA's Avatar
Subscribed.
JBrady
11-09-11 07:14 AM
stevechumo
Performance & Maintenance
01-18-09 05:24 PM
modifyd
Performance
02-21-06 07:56 PM
Jimbo2828
10-07-05 12:31 PM
reamemiya
06-19-05 12:54 AM
Quick Reply: LSD for the LS?
