Chip upgrade?
Old 09-29-16, 12:17 AM
klimber
klimber's Avatar
Default Chip upgrade?
are there chip upgrades for the gsf? I am wondering also what things I can do to increase the horsepower?
Old 09-29-16, 10:44 AM
flowrider
flowrider's Avatar
Received 1,947 Likes on 1,371 Posts
FBO is the way to go. Look in the RCF forum and you'll find what you need. Also, Forum Sponsor RR Racing is working on a tune.
Lou
Old 09-30-16, 03:08 PM
USBGSF16
USBGSF16's Avatar
Go get a INTAKE SET , A EXHAUST SET(APEXI HAVE IT IN STOCK NOW) ,GT HAUS CAN MAKE ON FOR YOU. AND RR racing has the tune. PPE has the header. So with I/H/E and tune you are able for 540HP at crank
Old 10-01-16, 07:19 AM
95bat
95bat's Avatar
Received 1,349 Likes on 695 Posts
Is there a dyno graph to show a 73 hp gain from those mods? Seems like a lot, especially for an NA car.
Old 10-02-16, 02:27 PM
USBGSF16
USBGSF16's Avatar
you can see those Dyno on RCF by RR racing, So it is about 40~50whp gain with full bolt on and tune. It is equal about 60~70 crank HP
Old 10-02-16, 02:48 PM
mikedozz
mikedozz's Avatar
That's not bad at all
Old 10-02-16, 03:28 PM
95bat
95bat's Avatar
I saw a dyno on there... I think 70 hp is a little optimistic. It would be interesting to see an independently done before and after dyno with a stock car.. Still seems like a lot of money for what you get. Isn't the intake/headers/exhaust combo with Apexi exhaust like $6000 for just parts? Or with GT HAUS exhaust closer to $8,000 for just parts?
Old 10-03-16, 11:51 AM
klimber
klimber's Avatar
eek! $8k for 70HP? am I reading that right?
Old 10-03-16, 05:55 PM
95bat
95bat's Avatar
The GTHaus website has their GS F exhaust for $4,000 (not sure if they're cheaper elsewhere), the PPE headers were $2,650 from RR Racing for the RC-F, probably safe to assume the GS-F headers are in the same neighborhood, then intake and the tune would be $1,000ish... so rounding down it looks like $7k plus install costs. Exhaust isn't too bad of an install, but headers can be a serious pain which can't help the install price. Even if you can find the parts cheaper, it's still quite a bit of money for the power gain. The exhaust note would be awesome fun, which factors into the cost as well, but it's not like it sounds bad stock.
That is a serious downside to Lexus... aftermarket parts are expensive.
I can add 200+ rwhp and torque to my car for less money!
Old 10-03-16, 06:08 PM
klimber
klimber's Avatar
supercharger a better way to go? Maybe they don't exist yet for the gsf?
Old 10-03-16, 06:20 PM
Afrosheen
Afrosheen's Avatar
Problem is, nobody has cracked the Lexus computer, so super/turbo charging is ill advised.
Old 10-03-16, 06:28 PM
klimber
klimber's Avatar
gotchya. That's surprising.
Old 10-04-16, 06:07 AM
ISFinferno
ISFinferno's Avatar
RR racing has already cracked the Lexus ECU issue. So Afrosheen you need to check your sources. They have it for the RCF and now the GSF. I have seen it myself since they used my GSF to check the programing of the ECU.
Old 10-04-16, 07:02 AM
Afrosheen
Afrosheen's Avatar
So a world's first, that's pretty impressive. Is this a piggyback ECU or does it integrate?
Old 10-04-16, 07:08 AM
ISFinferno
ISFinferno's Avatar
their is not addition ECU. He remaps the mapping on the actual ECU that's in your car. They figured out the CODE and they rewrite it based on what its needs. they also Dyno the car to make sure its at peak. He working on the supercharger kit for both the RCF and GSF.
Quick Reply: Chip upgrade?
