Need New Shocks
Need New Shocks
Took my car to get tires balanced. As usual, anytime I have my car on a hoist or wheels off, I have a look-see around to see how things are. Well, I noticed my driver's side, rear shock is leaking badly. So the hunt for replacements begins. I'm replacing all four shocks and I have NON air suspension.
I found a set on Ebay: http://www.ebay.ie/itm/272117581884?...MakeTrack=true
This is the first time I've seen a supplier other than KYB. I had been considering KYB Gas A Just or KYB Excel-G (one is monotube and the other is twin tube).
For 244 bucks for ALL FOUR shocks, I can't pass this up. They have a Lifetime Warranty.
Comments?
Comments?
texas008 (06-30-22)
How much is the shipping to you? Based on what it shows me its $141.25 for shipping which is not too much less than going with KYB. KYB is $412 plus shipping on Rockauto and they usually send a 5% discount to returning customers. I've never heard of DTA so I'd be weary. My experience has been you get what you pay for.
Hmmmmm, I have an oil change coming up soon. I'll have to inspect mine.
Don't be surprised to see them all looking good. Only my drivers side rear was leaking. The other 3 looked great (but they're probably tired regardless after 115k miles). That leaky one is so bad that the buffer/cushion was coated in what looked like grease....and thick
I've never even given mine a look...had it on the lift the other day for an oil change and never even thought about it. I did give it the usual inspection...control arm bushings, tie rods, wheel bearings, check for leaks, etc. I'll have to take a look at my struts next time. Let us know what you do.
Did you notice any difference in absorbing bumps coming from that rear left side, or any impact on handling?
The previous car I had was notorious for struts leaking and going bad at around 90k miles. The RL, while not as heavy as this, was a fat hog nonetheless and apparently eats struts like mad. It's a common issue and it's all over their forums.
One thing that was shocking to me was how much the ride improved after replacing them. But, the funny thing about this was that prior to changing them, it felt normal to me, just because the degradation in quality is typically slow as molasses and imperceptible over time, unless one blows out completely.
I was anazed how much smoother and less jarring it was by just swapping out those old, tired struts. I couldn't tell they were bad until I had new ones and honestly I think that's fairly common since we ride on these things for eons. I did notice "thuds" over jarring bumps, but again, it felt normal to me because I got use to it and it came on slowly.
Theres a huge thread about KYBs on Acurazine and multiple reports of new ones leaking, weeping and failing after a year. Of course, many people have reported 50k miles without issues too. I ended up replacing mine with OEMs. Replaced the bump stops as well as it was aging and failing due to the struts periodically hitting them.
In any case, good luck and yeah, if your car has 90k+ miles, I would definetely inspect them. Like any mechanical, load-bearing part, they wear out, especially on a beast of a car like ours.
