LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
headlight replacement 08 LX570
Old 08-28-16, 01:21 PM
BadBoy
BadBoy's Avatar
Default headlight replacement 08 LX570
anyone know of a good replacement? mine are all hazy and yellow.
Fred
Old 08-28-16, 01:52 PM
Chocolate
Chocolate's Avatar
You can try buffing/polishing/and sealing the lights. Lots of tutorials online if you search. If they are too far gone, your best bet/price will be a set of used OEM lights on eBay.
Old 08-28-16, 05:09 PM
hankinid
hankinid's Avatar
I had great results using 3M's polishing kit...about $30 at your local parts store. All you need is an electric drill. This was on wife's horse hauler Ram 2500. You'll get a better job if you can pull the headlight assemblies...if you can't do that, double or triple masking tape over painted areas close to the headlights works well.
hth
Old 08-28-16, 06:57 PM
Chocolate
Chocolate's Avatar
hth
Yes, you can get great results as long as the wear is on the surface, once the plastic hazes too far it needs to be replaced.
Old 08-29-16, 08:26 PM
DocT
DocT's Avatar
These guys have told you everything but left one thing, use Meguiars Ultimate Compound.
Old 11-19-17, 04:08 AM
lotus
lotus's Avatar
I have a 2008 also with yellowing headlights. I used the 3M kit with good success, however it returned in 6 months and appears even deeper then before. I would assume there was a factory UV filter on outer layer that wore down the first time, but the first 3M treatment likely removed quite a bit of material and final exposed layer looked great and smooth, but was much more susceptible to UV damage.
At this point, I feel the plastic is too thin. I also may point out there are sealers that claim to slow down this issue, but haven't tried any.
Old 11-20-17, 03:32 AM
lexusrus
lexusrus's Avatar
How about trying this process. Only cost like under something like $8. The supplies are way more than needed to do both headlights. If you buy the Rust-Oleum American Accents Ultra Cover 2X Gloss Clear Spray Paint and Primer 12 oz at Walmart it is only $3.86 versus Amazon at $22 for the same thing. The sand papers are relatively inexpensive.
Fred
Luxlex5
04-05-19 07:19 PM
Fonzopin92
27
12-12-12 08:55 PM
Mancebof
03-09-12 08:35 PM
blklexo818
06-15-11 07:57 AM
Todd
01-03-10 07:20 AM
Quick Reply: headlight replacement 08 LX570
