Sc300 Radiator Options
Old 08-25-16, 12:05 PM
eknine9
eknine9's Avatar
Default Sc300 Radiator Options
So my Radiator decided that after 24 years it was tired of my **** and cracked, sprayed fluid all over my window, and through the open driver side window on to my face. Thankfully the coolant was true to its name and didn't burn me, but it was definitely hot. So I'm looking around for an aftermarket option for the SC300.
So far it seems as if the Koyo, and Mishimoto Supra radiators will "fit" but requires trimming the battery tray and some other modifications. However I want something that I can install with no modification whatsoever. I currently do not have a fan shroud so I'm looking for any radiator options that will fit without requiring me to do any modifications. I have a stock 2jz-ge. Just curious what you guys recommend.
Old 08-25-16, 01:19 PM
freakness
freakness's Avatar
Dude,
Just buy a Denso, which is the original equipment supplier.
http://www.rockauto.com/en/catalog/l...le.com+URL+%2F
$84.79 is a good deal.
Old 08-25-16, 02:39 PM
Gee44
Gee44's Avatar
I was in the same situation a few weeks ago where my radiator cracked at the top. I bought this same one mentioned and took the time to change over to the Toyota "Red" as well. This radiator fits perfect on a 99 SC300. It's a two core instead of a one core listed for a 99. I hope this helps...
Old 08-25-16, 07:46 PM
BlackIRON
BlackIRON's Avatar
I bought this radiator for my 96 and it fit perfectly. But i would get freakness' now that i see the price lol. I do wonder about the Mishimoto one though,
Old 08-25-16, 08:21 PM
Ramblerman
Ramblerman's Avatar
There are actually quite a few options for rads for our cars. Don't buy any thing with a plastic tank. They're garbage! I found a new 2 core copper and brass for mine for 2 hundred. There are of course the all aluminum options also. Shop wisely my friend.
Old 08-26-16, 08:01 AM
RXRodger
RXRodger's Avatar
Just buy the RockAuto offering. Plastic tank? You just said yourself yours gave up the ghost after 24 YEARS so don't be afraid to invest the $85 for another one, I am sure it will outlast the car.
Old 08-26-16, 09:21 AM
Halon
Halon's Avatar
+1 for just getting a Denso replacement. My stock one cooled the car just fine, so didn't see the need to buy a more expensive aftermarket Supra one that requires a bit of tweaking to fix. New Denso replacement will install just like factory. I just bought one on the auction site last night for $70 shipped (Denso 221-3118).
Old 08-26-16, 08:49 PM
scsexy
scsexy's Avatar
You really should get the fan shroud it helps cool the car
NYCsc300 (01-15-20)
Old 08-27-16, 02:17 AM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
^^ I also agree with getting a new OEM spec Denso radiator. You can get it from Rockauto or direct from their densoproducts website. The Supra spec Koyo and Mishimoto radiators are both very good but will not be needed unless you are planning to turbocharge.
Additionally, you REALLY do need the OEM SC300 fan shroud and the lower plastic for it. That is what keeps the airflow from your mechanical fan efficient and directed onto the radiator's fins.
The extra modifications needed to fit Supra MKIV style radiators and fan shrouds all amount to the same thing, just with higher cooling capacity.
Old 08-27-16, 11:35 PM
t2d2
t2d2's Avatar
Isn't it the other way around? I thought the fan blows away from the radiator, as part of the push-pull with wind forces through the grill, and the shroud helps funnel that action so the fan's air movement can only come from the radiator.
Old 08-29-16, 08:31 PM
eknine9
eknine9's Avatar
Went with the OEM Denso.
I thought there would be more options for our car that didn't require modification.
Old 08-30-16, 06:28 AM
Halon
Halon's Avatar
Good call. My new Denso showed up yesterday. So clean and OEM looking, I love it!
Old 08-30-16, 08:43 AM
INTIMAZY
INTIMAZY's Avatar
When did they switch over to plastic end-tanks for OEM?
My 92 is still on the original radiator but it doesn't have plastic end tanks...?
Old 08-30-16, 08:57 AM
Halon
Halon's Avatar
I can definitely tell you this one is different than the 92 one I pulled out (see pic below). But my factory 92 one for sure had plastic tanks.
I could definitely be wrong, but my understanding is Denso is the current OEM supplier. I couldn't tell you if Denso simply changed their design from what they offered in the 90's, or if it was in fact a completely different supplier back then such as Koyo or Aisin. None the less, it's a direct factory replacement, fits perfectly, and Denso is an OEM brand in general so you can expect that level of quality/fitment.
Old 08-30-16, 06:12 PM
1997Soarer
1997Soarer's Avatar
I believe there are more Japanese radiator options out there for the JZZ Soarer. But, you would have to search each Japanese powerhouse to find them. No one mass produces them.
For example, a couple years back Koyo made a Soarer specific radiator that was Supra width and a direct bolt-in. I wouldn't be surprised if they still make it.
Now why don't they offer it here in North America? Well, that's where you would need to get in contact with Koyo USA. I would assume that even if they brought it here, people would have a hard time paying $500 for a radiator.
LSEGHATCH
16
11-03-09 11:13 AM
tampa mike
05-13-09 10:59 AM
crazyspeed
21
07-11-08 01:30 AM
sc3dreamz
08-09-06 01:02 AM
dre300
03-23-05 10:11 AM
Quick Reply: Sc300 Radiator Options
