2006 LS telescoping steering wheel qustion
Old 07-27-16, 01:09 AM
jbonez89
jbonez89's Avatar
Default 2006 LS telescoping steering wheel qustion
can you disable the telescoping wheel when going in and out of the car, i dont want to wear out the motor as i keep it in only 1 position, i aprreciate the help
Old 07-28-16, 12:43 PM
shmi
shmi's Avatar
From what I understand, the dealership can do it. Might also be possible with the toyota/lexus software on a laptop along with the cable, but not sure.
Old 07-28-16, 01:30 PM
hyperopt
hyperopt's Avatar
100% doable with TechStream and a correct adaptor running on your own laptop.
Old 07-28-16, 04:42 PM
rkw77080
rkw77080's Avatar
Disabling these functions with Techstream will disable the automatic-telescopic and auto-tilt only. You will still be able to make manual adjustments.
Alternatively, you can totally disable these functions (auto and manual) by removing the power to the motors. With the car running, adjust the telescopic and tilt to the desired position. Leave the car running and pull the 20A fuse called TI&TE in the driver-side fuse box (see diagram below). Just put the fuse back when you want to restore these functions.
Old 07-28-16, 06:20 PM
FatherTo1
FatherTo1's Avatar
Thanks, rkw! I plan on doing just that (pulling the fuse).
Old 07-28-16, 06:27 PM
jbonez89
jbonez89's Avatar
i want to disable to auto tilt when u get in and out of the car but keep the manual tilt in case i or someone else needs to adjust it
Old 07-28-16, 07:31 PM
rkw77080
rkw77080's Avatar
OK in this case, Techstream is your answer. You can pick one up at Amazon.com for around $20. You can find many tips by doing a search for "Techstream" on this forum. Attached is a listing of neat things you can do with Techstream. auto-tilt and auto-tele is on page 7.
Old 07-28-16, 08:58 PM
bmore430
bmore430's Avatar
Subscribed. Telescopic motor just failed on my 2005. Replaced the tilt 2 years ago. Trying to decide if I want to disable the steering or bite the bullet and replace.
Old 07-29-16, 11:47 AM
jbonez89
jbonez89's Avatar
Thanks brother i adjusted the wheel where i wanted and pulled the fuse, worked like a charm, and i just bought the Aiken 021 waterpump & belt saved me $140
Old 09-11-16, 07:50 PM
tallcaguy
tallcaguy's Avatar
Thanks this is pretty cool. Is there any way to recalibrate the speedo for different size wheels? Fix the sometimes slow upshifts on an 04 transmission when using the manual shift? My indie shop disabled the tilt/telescope for me. It's handy to know what they did. Thanks again.
Old 09-12-16, 11:45 AM
aypues
aypues's Avatar
Thx RKW! Super helpful as usual! I noticed the date on the pdf is 2001. Are there any other functions for 04-06 vehicles not in this article?
Old 09-12-16, 03:00 PM
rkw77080
rkw77080's Avatar
Attached are pages from the 2004-2006 repair manual on Customize Parameters. I suspect that the PC version of Techstream can only customize a sub-set of these parameters, while the others can only be customized with a "real" Techstream the Lexus/Toyota dealer uses.
File Type: pdf
philipwk
06-06-18 09:19 PM
peenlrd
03-27-18 07:09 PM
Aliceto
GS - 1st Gen (1993-1997)
03-27-16 09:56 PM
05Flagship
08-24-15 07:02 PM
SC300_704
11-10-11 04:24 PM
Quick Reply: 2006 LS telescoping steering wheel qustion
