Was rust an option?
Old 07-24-16, 12:33 PM
dicer
dicer's Avatar
Default Was rust an option?
In the pursuit of perfection, and the other very nice small details that were done in the construction of these cars you would think all the metals that could corrode would have been protected. Like these brackets that hold the plastic retainer *****.
This is a picture of the driver door panel on the inside. Gen 1
Old 07-24-16, 12:38 PM
litesoarer
litesoarer's Avatar
Ah yes, this was in fact a $1,895 option.
Old 07-25-16, 08:17 AM
jaaa
jaaa's Avatar
You can never stop rust, you can just slow it down.
Old 07-25-16, 04:29 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
So you're upset that a 25-30 year old vehicle with an unknown history has a few spots of surface rust on a support clip on the INSIDE of a door card?
Someone sound an alarm, Lexus must be be cutting costs....
Metal + water + time = rust. This is inevitable, even the best coatings will fail with age.
Old 07-25-16, 04:33 PM
Losiracer2
Losiracer2's Avatar
Isn't that part of the door panel sealed from the outside environment either by the rubber door seals or the thick plastic sheet they put behind the door panel blocking out any dust or moisture intrusion?
My AZ car has zero rust, maybe you should've bought a car from here.
Plus, if they were to rust coat everything, don't you think that would drive the cost up a bit? Cost plays a big role into what gets more attention, better quality of materials and coatings added to it. They didn't think that people would still be driving these cars 25 years down the road. With yours being a 91 model, Lexus was still a pretty new company testing different things and "perfecting" despite being a division of Toyota.
Old 07-25-16, 04:59 PM
dicer
dicer's Avatar
Pursuit of perfection !!!!!!!!!!!!!
When they flet pad all the little clips that hold in some of the items like the ash tray, yes I do expect that.
When they plastic insert nuts for sheet metal screws, yes its not that difficult to dip the simple parts in a coating. I used a dremel wire brush and clear coated them.
Old 07-25-16, 05:57 PM
RA40
RA40's Avatar
They are hoping you'll buy a LS430, 460, etc.
Old 07-25-16, 07:36 PM
dicer
dicer's Avatar
Too many air bags for me.
Old 07-25-16, 09:55 PM
RA40
RA40's Avatar
Secure foam...
Old 07-26-16, 04:17 PM
GasBuggy
GasBuggy's Avatar
In reality, even after 60 years, they would still be solid.
kwb18
08-11-17 11:51 AM
BailsVT
04-29-14 12:30 PM
xknowonex
01-15-14 08:54 AM
YoshRX300
RX - 1st Gen (1999-2003)
11-19-07 03:41 PM
olddog
05-06-07 10:43 AM
Quick Reply: Was rust an option?
