Weird screech issue with 07 2IS - HELP!!
Hi guys,
My car audio used to act up in that the audio simply would not work. After someone on these forums hinted it could be moisture related I managed to dry out the amp and things were working fine. Now, as of a couple of days ago a new issue has started, its a little hard to describe so here is a video clip of it -
Any help would be much appreciated!
Does it do that when using aux or cd?
If yes then maybe there's a faulty power wire running close or near your speaker wire. Do you have an aftermarket system at all?
Does it happen right when your deck is turned on?
Have you reset the ecu by unplugging your battery?
I have not unplugged the battery yet. Will get that a shot tonight. Thanks!
Edit: Also, it is a completely stock system.
Where would I check the grounds?
Thanks bud, thats what I am looking to do as well. I narrowed down the issue to one channel (front speakers) and disconnected that cable from the Amp. That just meant that I could take my time looking for a decent second hand amp. If you know of a good place that does international delivery, let me know!
RAMAIR
09-16-11 02:37 PM
tudor
01-15-09 12:19 PM
2slow
07-25-07 10:50 AM
