DIY analog air suspension controller
Old 05-23-16, 12:29 AM
Owczar
Owczar's Avatar
Default DIY analog air suspension controller
Hi,
I am working now with new project - DIY analog air suspension controller. I have found that height sensors are equiped with potentiometer so I have decided to use that information to manipulate feedback to achieve desired reaction from air suspension controller. This is not final solution but tests proved that will work as I suspect.
I will put switches into armrest After switch off, air suspension will work as without additional controller.
Solution will not be pnp. I haven`t oem connectors so it is necessary to solder 12v wires to oem harness.
More details soon after drive tests.
Old 06-12-16, 09:52 AM
Owczar
Owczar's Avatar
Finally I found some time to finish project.
There is ability to regulate height of all wheels individually. After height pre setup by potentiometer (5kOhm linear) I switch controller by two buttons on armrest. I can turn it off in any time. I could lower the car in couple of seconds by two switches. Lights auto leveling works without any problems as before. Air suspension react in the same way. By four potentiometers I manipulate in feedback from air suspension height sensors.
One switch is for lowering front of the car and the second one for rear.
I made one panel for mirabox switches and air suspension controller casing.
Total cost aprox 5$ and couple of hours to made wirings and casing.
Potentiometers are bolted in the casing:
There is an access to regulate potentiometers:
Buttons mounting:
Casing in alcantara:
Controller in armrest:
Photos:
Normal mode:
Low mode:
And movie. Suspension need some time to change position. Rear at first, the front.
Sorry for my english - I am still learning.
Old 06-12-16, 11:29 AM
radohanno
radohanno's Avatar
fantastické.....
Old 06-24-16, 03:55 AM
Owczar
Owczar's Avatar
Converter was calibrated to 66cm (26") (from ground to fender). Car looks like on the photo:
If anyone would like do the same controller I added wiring schemat as attachments.
File Type: pdf
File Type: pdf
File Type: pdf
rhysuuu (12-17-17)
Old 01-16-17, 01:43 PM
altez
altez's Avatar
Hi, do you have a wiring diagram on the 2006 Lexus?
Old 01-16-17, 01:47 PM
Owczar
Owczar's Avatar
What do you need exactly?
Old 01-16-17, 01:49 PM
altez
altez's Avatar
the wiring diagram of the ride height sensors to the air suspension control unit
Old 01-16-17, 01:54 PM
altez
altez's Avatar
I want to connect a third-party controller is pneumatic, and connect it to the factory ride height sensors to the stump of the required wiring diagram on the air suspension from the Lexus 2006
Old 10-18-17, 03:52 AM
Makela
Makela's Avatar
Where is located this original suspension controller? Where did you make your connections to original wiring harness?
Old 10-18-17, 06:10 AM
Owczar
Owczar's Avatar
Original controller is under passenger box. I have connected to harness near the original controller as on below photo:
Old 12-17-17, 07:17 PM
rhysuuu
rhysuuu's Avatar
I will attempt to replicate this onto my 89 Celsior. I am sure the wiring diagram will be slightly different but the overall principal will remain.
Old 04-08-20, 07:15 AM
Simis
Simis's Avatar
Do I need to disconect something from ecu? Or do i need to do all wheels at once, i tried on front only and it did not lowering the car.
Old 05-12-20, 06:19 PM
mdanfas
mdanfas's Avatar
​​​​​​ Try doing both front sensors and it should work. This is just used to fool the car's air suspension ECU to give it a different height sensor reading.
PlatES300
07-01-17 09:08 AM
gcam77
GX - 1st Gen (2004-2009)
06-14-16 12:12 PM
LiCelsior
04-15-09 08:44 AM
Quick Reply: DIY analog air suspension controller
