What typically causes power window failure?
Old 06-16-15, 11:35 AM
Oro
Oro's Avatar
Default What typically causes power window failure?
The RR window has stopped operating, fortunately while in the up position. I can hear an actuator or solenoid fire when I hit the button, but nothing else. What part is the usual culprit here; seems to me to mean the motor.
EDIT: OH - found this old thread re: TSB on issue of regulator sticking. Will have to try that first later tonight.
https://www.clublexus.com/forums/es3...w-problem.html
Old 06-16-15, 07:13 PM
Oro
Oro's Avatar
Yep, that worked.
I powered on the ignition, got in the rear seat and pulled the door closed hard while holding the button down. Window came right down and operates normally now.
Old 06-17-15, 04:46 PM
hypervish
hypervish's Avatar
Sweet, gotta love that "fix"! I did the same once I bought my ES, of course after I had them deduct some $$ from the purchase price. lol
Old 02-22-17, 04:26 PM
blckphillp
blckphillp's Avatar
just like i always make sure i have my keys before i lock and shut the door, I always look to make sure my Sun Visor isn't poking out through my driver's side window --especially if the extender is out-- before I roll up the window. Thats how i f*%* My last car window up...the automatic power window clamps up on it, and the strain will break or bend or kink the internal track, wire pulleys, cables, etc. in a Heartbeart! and that means no easy Fonz Jukebox Fix. That's a trip to the junk yard fix.
Old 06-21-17, 06:08 PM
scuz75
scuz75's Avatar
Power window failure is usually the window regulator or the switch itself.
beachit321
02-28-18 06:54 PM
UDel
09-03-16 02:07 PM
dd0615
04-04-13 06:29 PM
Benchwrnch
08-10-07 03:49 PM
Quick Reply: What typically causes power window failure?
