CA 01 GS3 Part Out Clearing
Check below for the latest parts & prices. If you see it, it's available. All prices are OBO and it is being parted from my garage.
All parts are from an 01 GS3; millennium silver / gray interior. These are parts that had to be removed to sell other parts. Of course, they are not going back in and are taking up space. Check post #1, I will add/remove parts as they become available/sold and change prices.
SOLD - fenders, front upper control arms, dash board, front airbags, all tail lights, trunk lid, ABS master cylinder, climate control, engine/tranny, seat belts, outside rearview mirrors, cat back exhaust, F/R bumper covers, front seats, differential, instrument cluster, climate control, bumper foam, air box, driver door & handle, hood, ML amp, driver window switch, front driver & pass door ECU, igniter
Pass servo motor - $70
Wiper motor assembly - $115
Sunshade - $75
Rear deck - $70
Floor carpet - $150
Headliner - $115
Front brake rotor - $35
Gas tank - $105
F/R bumper reinforcement - $40
Left rear door - $90
AC unit - $175
Blower - $130
Door sills(4) - $75
Rear driver speed/ABS sensor - $80
Front sway bar - $35
Gear shifter - $145
Side airbags - $60
Sunroof glass - $110
Rear seats - $180
JDM Aristo strut bar - $200
Floor mats - $25
GS3 mass airflow sensor - $50
CD changer - $70
Rear wheel well liner - $25 each
Door handle - $25
Steering rack - $190
Front brake calipers - $85
Rear brake calipers - $60
Drive shaft - $90
Trunk nav mat - $50
Trunk floor board - $50
Pass windows switch - $75
Door panel - $75 EACH
Door glass - $60 EACH
Front cat - $230
Rear cat - $180
Steering shaft- $95
Shocks/struts/springs - $125
Rear Mark Lev speakers - $50
re-Key/lock set - $295
Rear axle - $75 EACH
FR window regulator - $30
Lock & lugs set - $50
R Front hub/knuckle - $90
AC condenser - $70
Rear window switch - $60 each
Washer reservoir - $75
Glove box (lock not included) - $60
Door scuff plate - $30 each
Upper center pillar - $50 each / $95 both
Lower center pillar - $45 each / $95 both
Driver lower dash - $60 (lock not included)
Luggage scuff pad - $40
Center console - $75
Engine cover $80
Rear speakers $35
Compass displays "--" but dimmer works fine - $35
Visors - $50
Steering wheel - $195
Sunshade - $75
Rear deck - $70
Floor carpet - $150
Headliner - $115
Gas tank - $105
AC unit - $175
Blower - $130
Door sills(4) - $75
Gear shifter - $145
Side airbags - $60
Rear seats - $180
Floor mats - $25
CD changer - $70
Door handle - $25
Drive shaft - $90
Trunk nav mat - $50
Front cat - $230
Rear cat - $180
Steering shaft- $95
AC condenser - $70
Engine cover $80
Rear speakers $35
Visors - $50
Yes, it will fit physically. You will have to do some work with the electronics & airbag.
https://www.clublexus.com/forums/gs-...bag-plugs.html
https://www.clublexus.com/forums/gs-...wheel-off.html
https://www.clublexus.com/forums/gs-...e-airbags.html
Yo ntran, I received the driver side fog and the side mirror last week. They are in excellent shape. They came in two days. That was super fast!!. Nice packaging too. Thanks a lot.
