95 sideview mirror on a 92 SC400
The problem I'm having is, I bought a 95 side view mirror used for a 92 SC400. When I put it in, it does not work properly.
It moves ^^up & <<left
but wont move >>right & down.
Also my right side mirror only operates in one direction now.
My original mirror from the car worked fine mechanically, the problem I had with it was the base got broken & it wont fold properly. I checked the fuses & the mirror ECU and they're fine. This is really strange & I wanted to know if the 92 & 95 mirrors were interchangeable. Ive checked for this on previous threads but it was not the same situation as mine so I beg whom ever knows the answer, please give me a hand.
Thank you.
Thank you.
According to R&J salvages site 92-96 door mirror's are compatible.
http://stores.ebay.com/R-J-salvages_...0Q2em14?_pgn=3
Its weird how time flys...
fast forward to 2017 im in a similar situation again. I bought another used mirror for my 92 but the replacement mirror is from a 97, the plugs are indeed different. Is it possible to make a 97 mirror work in a 92 SC?
718murdoc (03-27-17)
I think ill try to see if i can get the old mirror harness/plug sliced with the new mirror.
Here's what the aftermath of wiring a non-dimming mirror into my '98 looked like:
https://www.clublexus.com/forums/bui...ml#post9571415
Fortunately, they hacked up the mirror side of the wiring, not the body harness side, so it was plug 'n play once I found the proper replacement.
Bentley1
13
01-26-03 12:44 AM
