97+ sc300 DIFF ratio
i know the pre 97 SC300's came with a 4.27 gear ratio. i think same for the sc400?
i believe the gear ratio is different in the 'newer' 97+ SC's?
99 to be exact.. anyone know what the gear ratio for it is? the pumpkin on them (92-00) are all the exact same correct?
92-97 SC300
6 cyl, AT (4.27 ratio)
6 cyl, MT (4.08 ratio)
98-00 SC300
92-96 SC400
8 cyl (3.92 ratio)
97-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
w/o turbo; (4.27 ratio) Limited Slip
w/turbo, MT (3.133 ratio) Limited Slip
w/turbo, AT (3.769 ratio) Limited Slip
97-98 MKIV Supra
w/o turbo; (4.08 ratio) Limited Slip
all taken from clubna-t
98-00 SC300
92-96 SC400
8 cyl (3.92 ratio)
97-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
97-98 MKIV Supra
The SC300 was 4.27 for the auto trans all years.
The SC300 M/T was 4.08 for all years.
SC300 and SC400 pumpkins are identical.
Note: Club na-t info is wrong in the case of the 97 SC400. The 97 has the four speed trans and a 3.92 ratio. The drivetrain of the 97 SC400 is identical to the 96.
thanks a lot guys! very informative and simple! i'm almost 100% positive that the TRD differential or the Torsen diff from the auto supra turbo would fit in with any of these gear ratios then!
sweeet
sweeet
392, 427, centrifugal, diff, differential, gear, gs300, lexus, limited, ratio, ratios, sc300, slip, supercharger, trd
