DIY Fender Rear Shave
Old Apr 26, 2007 | 09:59 AM
carbongs's Avatar
carbongs
Default DIY Fender Rear Shave
So, after I installed the wheels:
EXE-Konvex 20x9 front and 20x10 rear. +37 and +35 offsets
and tires:
Dunlop Sport Maxx 245-35-20 / 285-30-20
and took a ride with Patrick, Bing, his brother Joey, and his son, I noticed that there were some rubbing issues between the sidewall of the tires and the fenders. After much research of how people have done it I took it into my own hands to do it my way.
In this picture you can see the rear fender and the tire and how it rubbed.
This is how it sits
So here we go! follow along!
Loosen the lug nuts
Jack your car up and use a jack stand for safety as well
I remove the jack so that it isn't in the way
Remove the wheel completely and keep all your tools and parts together so you won't lose them
Old Apr 26, 2007 | 10:00 AM
carbongs's Avatar
carbongs
Now you will need a phillips head screw driver. Only 4 screws to remove and here is where they are.
You'll see that the lining piece will come off like so
once again leave all parts and tools together as so you won't lose them
depending on your set up you will have to remove what you need. i measured mine and i was going to take a little more than half an inch off
the next step is to tape it off so that what you want to keep is under the tape. this will halp later from scratches etc...
Old Apr 26, 2007 | 10:01 AM
carbongs's Avatar
carbongs
now you are going to need a dremel tool, reinforced metal cutting wheels, safety glasses, and gloves.
simply follow the line and be carfeful. take your time and do it right the first time.
i'm cutting lines into the fender to take it off later here
after only 4 inches i used up a whole wheel. *pointer - dremel a line first for the whole line you want to cut and work your way going back over the line again and again. this will save you some bits*
Old Apr 26, 2007 | 10:02 AM
carbongs's Avatar
carbongs
just keep going and you'll be done in no time. once you are done sand off the edges and use some touch up paint and you will be set to go! the whole project took me 1.5 hours since i was scared to mess up. but good luck and happy shaving.
End result:
carbongs's Avatar
carbongs
so now i will be able to lower with no problems in the rear. off to do more research on how to do the front end fenders.
Old Apr 26, 2007 | 10:09 AM
golfkid777's Avatar
golfkid777
I will be doing this very very soon. Mine is pretty much a constant rub right now... Need to change out the 265's for 235s and get a little shave and roll action going on and all will be well!
Old Apr 26, 2007 | 10:10 AM
golfkid777's Avatar
golfkid777
Oh and for the front end fenders they are pretty much already rolled. I am pretty low witha lot more aggressive wheel set up than you and I dont rub one bit in the front no matter how big the bump.
Old Apr 26, 2007 | 10:15 AM
SBMGS4's Avatar
SBMGS4
Great write-up and pics!!!
Old Apr 26, 2007 | 10:32 AM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
Nice DIY carbon... I like that front bumper with the IS fogs.. Nice job..
Old Apr 26, 2007 | 10:36 AM
Lettuce's Avatar
Lettuce
Nice little DIY thread...Seems like your car would not need that especially sitting so high.
Old Apr 26, 2007 | 10:52 AM
milky's Avatar
milky
nice little write up! I didnt know the dremel wheel was strong enough to cut through the car fender
nice way to save $100 or so..
Old Apr 26, 2007 | 11:04 AM
Emackny's Avatar
Emackny
Excellent write up bro!
Old Apr 26, 2007 | 12:33 PM
carbongs's Avatar
carbongs
thanks man, can't wait to see your set up!
Old Apr 26, 2007 | 12:34 PM
carbongs's Avatar
carbongs
thanks!
and thanks tmf2004! appreciate it. i really like how it turned out.
Old Apr 26, 2007 | 12:37 PM
carbongs's Avatar
carbongs
it has the stock suspension on it now and with 3 grown adults that aren't really skinny in it, she scrubbed bad. with as many bumps and potholes as we have in my area it needed to be done. it is getting lowered really soon. i purchased a used suspension from a friend of mine who is going from kyb struts and eibach springs to tein coilovers. they only have 10k on them and he hooked me up. but he hasn't switched them out yet so i am waiting. in the mean time i'm getting the car ready. i like how she sits now for practicallity issues. but for show purposes i'm going to have to lower her.
