DIY - How To: Transmission Mount Change SC300/SC400 5spd or Auto
Old 01-14-06, 09:46 PM
TMaxxTim
TMaxxTim's Avatar
Default DIY - How To: Transmission Mount Change SC300/SC400 5spd or Auto
I recently replaced my transmission mount on my 1992 SC300 5spd. It didn't look shot when I first looked at it underneath the car, however once I got it off it was clear how bad it actually was. My ride has noticably improved and everything is much smoother. This is for a 5spd, however I am SURE that the procedure is about the same for the others as everythign bolts up the same for the transmission mount (the positioning of the bolts is different, however I am sure anybody that is willing to tackle this task can figure it out).
When you get under the car, you want to jack up the transmission a little so there is not much weight sitting on the mount. I had to use 2 bricks to hold up my jack higher because my car was already on jackstands so I could get underneath it.
Once I got the transmission lifted a little bit, there were 4 bolts on each side of the transmission mounting plate which bolt to the car (this isn't what your replacing, it goes below the mount. It also has 4 nuts you need to take off that connect directly to the mount.
After you remove this, there will be 4 bolts, and depending on which car you have, they will be positioned differently, however you can see them all, simply remove all of these from the transmission.
The mount will now drop out for you to remove.
Replace the mount and redo the steps in opposite order.
You're Done!!!
Now drive your car and see how it feels! It shoudl be a lot smoother and shifts won't be as jerky, especially on 5spd cars!
BTW: I got the mount from Sewell Lexus for $47 I believe, not bad at all.
Old 01-14-06, 09:47 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
great job
Old 01-15-06, 12:05 PM
kylessc400
kylessc400's Avatar
good job...i was waitin for someone to change their mount because i think i need to change mine......
thanks for the write-up and everything....great pictures as well
Old 01-15-06, 12:11 PM
TMaxxTim
TMaxxTim's Avatar
Thanks. Its really a 15-25min job depending on how stuck your bolts and nuts are. Just gotta be willing to lay on your back and get a little dirty
Really makes it feel like a Lexus again!!
Old 01-15-06, 08:13 PM
SharpCreas
SharpCreas's Avatar
Just changed two of my motor mounts and the trans mount in my SC400. Rides like silk. Congrats.
Old 04-22-07, 11:16 PM
ridox
ridox's Avatar
lexus part number for the mount? will a supra na 5speed mount work also?
Old 04-22-07, 11:30 PM
RedPhoenix
RedPhoenix's Avatar
good job! very helpful
Old 05-09-07, 06:54 PM
acenase
acenase's Avatar
What size are the bolts??
Also, once you remove the 4 bolts on the cover and exposes this:
What screws do you need to remove from this?
Old 05-09-07, 08:14 PM
TMaxxTim
TMaxxTim's Avatar
The ones on the top to remove the mount. I don't know what size they are, just put a socket to them and test.
Old 05-09-07, 08:17 PM
Sc400on20s
Sc400on20s's Avatar
Great DIY!!
Old 05-14-07, 11:31 AM
icec0ld
icec0ld's Avatar
just found this thread....great diy & pics too! looks like i'll be doing this after my lca bushings
Old 05-16-07, 05:00 PM
Fireblaze
Fireblaze's Avatar
Thanks, this has inspired me to change my mount.
Old 05-17-07, 01:38 AM
TheMole
TheMole's Avatar
I used these directions to change the trans mount on my sc300 auto. I have to admit that it was pretty straightforward. Good job!
Old 08-19-07, 06:27 PM
CptCrunch
CptCrunch's Avatar
hey, im about to change my tranny mount on my sc5spd. i got the mount from toyota that is for a supra. Part# is 12371-46090, will this bolt right up? i see that our stock mount is different from the mounth you installed. let me know if thats the correct part that will fit. thanks!
Old 08-20-07, 02:36 PM
mills88
mills88's Avatar
Nice DIY. Thanks, now I might actually do it!
Quick Reply: DIY - How To: Transmission Mount Change SC300/SC400 5spd or Auto
