2003 rx300 ac compressor bearing
Old Mar 30, 2026 | 07:14 PM
Saltylures's Avatar
Saltylures
10th Gear
Default 2003 rx300 ac compressor bearing
Hello guys. I need help about the bearing size or number to replace it. is the brand Nachi? help me out please.
Old Mar 30, 2026 | 11:02 PM
salimshah's Avatar
salimshah
25 Year Member
I have not seen any post where a member has tried to replace compressor bearing. So give it a few days and see if anyone responds. You can also try to ask in highlander forum. Or take the bearing out and let the store match it for you.
Salim
Old Mar 31, 2026 | 04:24 AM
Saltylures's Avatar
Saltylures
10th Gear
Default Yes I will wait
Thank you for replying. I crossed referenced the ac compressor of the Lexus with the Toyota and they are the same on rockauto.
Old Mar 31, 2026 | 07:17 AM
salimshah's Avatar
salimshah
25 Year Member
Don't over look purchasing a replacement compressor. Prudence requires flushing the circuit and as cost increases, it might be worth just buying a compressor.
rockauto is a good place. You can also check Amazon but you will have to dig a bit to ensure the item is legit.
Salim
Old Mar 31, 2026 | 07:25 AM
Saltylures's Avatar
Saltylures
10th Gear
Default Re.
I think I might just pull the clutch and pulley out and see if the part number is on the bearing. I have done this in other cars before so that's not a problem. I just didn't want to spend 300 bucks on a new compressor and then 300 bucks on a shop to vacuum and fill the freon. NY prices of course.
Old Mar 31, 2026 | 02:50 PM
maxSteel's Avatar
maxSteel
For $200 you can buy the AC manifold gauges and a nice vacuum pump from Harbor Freight
Old Apr 20, 2026 | 04:36 PM
Saltylures's Avatar
Saltylures
10th Gear
30BD5222dum6/AC is the bearing. NSK brand. Japanese make.
That1sc400
Oct 6, 2025 12:46 PM
Adlib
Jun 30, 2022 10:08 AM
Islandbob1
Feb 19, 2021 08:04 AM
