Trouble removing driveshaft need help.
Old Nov 23, 2025 | 11:54 AM
05ls430518's Avatar
05ls430518
Default Trouble removing driveshaft need help.
I am trying to remove the driveshaft from my car bolts are out and it is stuck I have pulled on it pried it both ends are stuck together at the bushing on both sides. The carrier bearing is unbolted as well .Did I miss something? I do not want to brake off any ends of something important by just he manning it out of there. Is it possible it is fused together because of rust it sat for 2-3 years in a gravel parking lot. This is holding me up any help would be appreciated
I am going to try to heat up the bushing with a heat gun and see id that will allow me to pry it off.
Old Nov 23, 2025 | 06:21 PM
paulo57509's Avatar
paulo57509
Did you miss a step? See attachment.
File Type: pdf
Old Nov 24, 2025 | 06:59 AM
weldthedif's Avatar
weldthedif
you usually have to get out a hammer and tap around it a bit to break it free, there may be rust sticking it
Old Nov 24, 2025 | 06:32 PM
05ls430518's Avatar
05ls430518
You where right I just smacked it a little bit qith a hammer and it came right out thanks man greatly appreciated
05ls430518's Avatar
05ls430518
Thank you for posting that great info to have
Neophyte2b
Mar 4, 2024 07:28 AM
PCW
LS - 5th Gen (2018-present)
Aug 20, 2022 08:35 PM
klynnsmith
Oct 22, 2016 02:08 PM
/Aerostar\
Dec 30, 2004 06:32 AM
