How to replace the rear brake, signal, and reverse bulbs in the SC 430
It's not difficult to replace the rear brake, signal, and reverse bulbs. But like everything else with the SC 430, a few photos make it easier, especially for people that are not big into mods. I used standard bulbs; Sylvania 7440 LL for signal and reverse, and 7443 LL for brake. These are available at auto parts stores and Walmart. I suggest replacing all of the bulb when one burns out. Slight differences in bulb specs between OEM and replacement might cause a false bulb-out indicator light if only one bulb is replaced. Also, the cost is less than $20 for all 6 bulbs.
The following 3 users liked this post by Hardtop430:
I Need to replace the DRL bulbs. Any procedure or photos write up will be appreciated. Thanks in advance.
Great pictures Hardtop. Thanks.
natetoms
GX - 1st Gen (2003-2009)
09-11-10 08:18 AM
