how to install trunk lid pistons
I bought replacement trunk lid pistons for my 2002 SC430 but need some help on how to remove the old ones & replace it with new ones. Any help?
Welcome to CL. Learn to use the Search function, located in the light blue bar above this message box; you can find answers to just about anything related to your car.
Here's a .pdf explaining how to replace the trunk struts that I found using the search funtion; My '02 didn't have the retaining pins that are shown in the attached instructions; I think they were added later. The ends of the struts pop off easily with a screwdriver. Make sure the new ones pop on securely and seat all the way. I used a broomstick to hold the trunk open. Good luck
https://www.clublexus.com/forums/att...acement-sm.pdf
Forget searching.. it will take alot of time looking up the answers your looking for..
I have the same problem a while back.. all you do is take a flat head screw driver and pull out the clips and pull them off and just push the new ones on.. its hard if its stuck.. just pull as hard as you can
wtf? your putting words in my mouth? i never said make someone search for them.. Im sure this user is would like to have a second option as to having to search countless threads.. so why dont yall make it easy for him and help him out by.. posting how to do it?
I have a friend who owns a 2002 sc430 I offered to help him change the trunk struts.
Can someone just explain briefly how I detatch the struts . I understand the 2002 does not have retainging pins . I read it that you have to use a screw driver to act as a wedge to pop off the strut ball socket . Am I correct or is there any other method to use
BUddy
BUddy
