LED Conversion Project
Old 06-12-14, 02:51 PM
  #121
ShawnOk
ShawnOk's Avatar
Ok so i had a chat with the pros over at iJDMToy and got some info. Apparently the front and rear turn signals MUST have some type or decoder or resistor to work properly and avoid the dash warning light. The OEM tail light (7443) is a dual filament (driving light and brake), so they make a special bulb for that application but it also uses a decoder. The front turn signal decoder would fit easily but the rear turn signal and tail light decoders, as there is no space, would be a tight fit. The ones labelled as "Error-free" would also work but are more pricey. Additionally, as the actual color of the rear housing is red and orange, it wouldn't really serve a purpose to change them especially since I'm using smoke tint film on the tail lights. I was only hoping to increase the brightness as I'm moving from 20% film to 5% film. He told me the brightness is the same as halogen and wouldn't cause much change. In the headlight though, it would only remove the slight amber tint of the turn signal behind the grooved glass. Anyway, so it seems that I won't be taking on the swap and will just leave things as is.
Old 10-09-18, 05:19 PM
  #122
gbdad
gbdad's Avatar
What bulb did you use for the DRL/High beam? And do you get both DRL & High?
Old 10-09-18, 10:12 PM
  #123
GmanSC
GmanSC's Avatar
Yes, you will have both DRLs and high beam, but the high beam is weak.
I had bad experience with the LED replacement so I would not recommend the product.
https://www.clublexus.com/forums/sc4...-disaster.html
However, others have successfully installed them.
Old 10-10-18, 05:42 AM
  #124
okievision
okievision's Avatar
I installed the iJDMtoy LED's, and while they did look good, losing my high beam wasn't acceptable. I put halogens back in.
Old 10-10-18, 12:29 PM
  #125
mandyfig
mandyfig's Avatar
That's what happened to me, back to halogens. I did use the whitest Halogen High Beams I could find, it actually had a bit of a violet hue.
Old 10-11-18, 03:40 AM
  #126
gbdad
gbdad's Avatar
Originally Posted by mandyfig
Here are go:
1. Prep and test all LED bulbs. I used alligator clips for the battery.
2. 7440 Reverse lights, easy twist off, replace, test and then plug in.
3. 168 Park Lights. The access is through the fender liner, remove trim, fold away the liner as much as required, it is ok because it will re-shape back. Twist off the assembly, mount LED, test to make sure it lights up, you may need to rotate polarity, also adjust the wire (pull away) to make sure contact is made.
4. 9005 DRL Remove the plastic trim covers on the sides. Note that the supplied decoder is wired wrong. I used the tester LED provided to confirm positive connection. RED wire to RED wire meant that I had to remove the tab and then I used tape to make sure the connector stayed plugged. The decoders will just lay outside the lamp assembly.
PASS side. In my case since I had the Injen intake, the air box was gone. Easy to pull out the DRL. Test the LED and then install.
DRIVER side. This was the tricky one. Be patient and you will need small hands to be able to get in there. I ended up cutting through the rubber covers to get in there.
Pictures:
Pictures help a lot, doing mine this weekend now that I know how & where to access!
mandyfig
08-29-12 12:58 PM
LEXAUDI
06-12-12 09:59 PM
KI_GSE21
RX - 3rd Gen (2010-2015)
09-05-11 01:47 PM
Quick Reply: LED Conversion Project
