Is there a seat memory relay on 2007 SC430?
My 2007 SC 430 seat memory and set buttons will not work on either door.
I have reviewed the owners manual and checked the fuses on both side kick panels but they are OK. The seat adjustment buttons work fine just the memory and set button don't.
Thanks for any help!
Have you tried to re-initialize the seats? See this thread, it's only four comments in length, with comments 2,3 and 4 applicable. seat memory initialization
VVTiBob,
Man you are the king of help!!!! Thanks very much it worked like a charm. I am in your debt, sir!!
Pat
Pat
Do you hear a beeping when the seats are being adjusted to the rear? If you do then:
After removing power from the car (the battery) the seats must be put through a full range of motion before the seat memory will work correctly: Move the seat position control switch forward until a beeping sound is emitted. Then move the seatback angle switch forward until a beeping sound is emitted. Do this for both seats.
Now you can set the seat memories normally.
For some reason the SC seat computers need to "learn" what the full range of motion after the power is removed. I've never figured that one out.
Thanks also.
VVTIBOB. I too thank you! As a Moderator with a great deal of experience, I am sure you forget how helpful your advice is. This is a great Forum with people like you!
CS-430 seat memory failure after battery replacement
Thanks to you for the help, I had this happen again today and had to refer to your earlier advice!!!!
dmxair
03-11-12 03:25 PM
