DRL lights out
Old 08-23-11, 06:37 PM
jzwu
jzwu's Avatar
Default DRL lights out
I flashed the high beam today and later found out my DRL lights are no longer lit when driving.
Anyone knows why? I tried high beam flash in my garage and the xenons flashed but not the DRL lights. Is that right? I thought the DRL lights are for high beam when turned on for that.
Old 08-23-11, 08:20 PM
cyberlexus
cyberlexus's Avatar
You DRL/high beam bulbs might have burned out. DRL lights should always be on.
Old 08-23-11, 08:33 PM
jzwu
jzwu's Avatar
Darn. I just put in the new PIAA DRL lights a few months ago. They were on this morning when driving to work.
I suspect it has to do with flashing the high beam. could it be the fuse?
Old 08-23-11, 08:39 PM
VVTiBob
VVTiBob's Avatar
Can't speak for on the road, but if your parking brake set while in the garage the DRLs are disabled. Check this thread: https://www.clublexus.com/forums/sc-...en-parked.html Comment #4
Also I suppose there is a chance the CBEST setting have been altered on your car. Check this thread, comment #3 to see what cbest setting can be modified in your SC. https://www.clublexus.com/forums/sc-...-my-02-sc.html Section 8 of the PDF on Light Control....DRL FUNCTIONS
Old 08-23-11, 09:23 PM
jzwu
jzwu's Avatar
I checked in my garage with the parking brake off. The DRLs are Still off.
Weird thing is they were on this morning. All I can remember was I flashed the high beam today. I will see if they come back on tomorrow.
Old 08-24-11, 07:17 AM
VVTiBob
VVTiBob's Avatar
Remember DRLs are the high beams but at reduced power as regulated by the ECM.
Old 08-24-11, 10:35 AM
jzwu
jzwu's Avatar
Yes, Bob. The DRLs are high beam at half the power, I think.
Today the lights are still out. I probably need to check the bulbs. Nothing else seems to be wrong.
luxe88
04-20-15 10:49 AM
Meraki Autoworks
IS F (2008-2014)
07-31-12 02:07 PM
TTechLexus
01-20-12 04:19 PM
mugenh22a4
IS F (2008-2014)
10-31-10 12:22 PM
rcnv
RX - 1st Gen (1999-2003)
07-25-09 11:11 PM
Quick Reply: DRL lights out
