Interior light help.
Old 06-02-10, 04:41 AM
atlantatan
atlantatan's Avatar
Default Interior light help.
Any one known what part number for foot light doesn't tell you on the manual,I want to change to led,thanks for any information.
Old 06-02-10, 11:14 AM
VVTiBob
VVTiBob's Avatar
http://www.sylvania.com/ConsumerProd...lacementGuide/
This is the link to Sylvania's automotive bulbs.... you'll need to enter your year make model info...but it's probably a 37 or 74 if you're referring to the ones in the footwell areas.
Old 06-03-10, 08:10 AM
justinbig8
justinbig8's Avatar
it's a tiny **** bulb, don't know what the part number is. actually i don't remember if it even came out...but what i did was buy 2 of the universal led kits from pepboys and splice into the wiring to the foot area lights. it wasn't the cheapest way of doing it i'm sure, but it works well.
Old 06-03-10, 10:25 AM
dunk123
dunk123's Avatar
it took me awhile to find it as well. Here you go.
Model # T5 / 286
I've already changed mine and looks great.
Old 06-03-10, 05:48 PM
atlantatan
atlantatan's Avatar
Thank you for the infor guys.
Old 06-04-10, 02:57 PM
daryltrinh
daryltrinh's Avatar
Bulb fitment: 74
Look up eBay#: 110430624609 (or anything similar
I found them to be bright and very white.
The fitment wasn't perfect,
but all i had to do was sand down the sides.
I'd order 3, 2 for each foot rest and 1 for inside the glove box.
Old 03-15-11, 05:53 PM
VIPNiSS
VIPNiSS's Avatar
i love the search function.
Thanks
Old 03-24-11, 04:57 PM
jeffwingo
jeffwingo's Avatar
I just installed LEDs that I bought frm eBay. I did the two map lights, the trunk lights, the two door lights and the license plate lights. It really is a huge improvement. The lights I got are brighter and whiter, but not too much so that they become obnoxious.
I recommend switching out the stock lights for LEDs.
Old 03-24-11, 07:24 PM
mandyfig
mandyfig's Avatar
Can you please give us the link for the seller? And which ones exactly? Thanks. How much were they, all together?
Old 03-24-11, 07:26 PM
VIPNiSS
VIPNiSS's Avatar
Mandy,
I did this for Kristi's car already as well. I did both dome/map lights, door lights, trunk lights, and foot well(still waiting for in the mail).. All mine came from China from different sellers and they look great!
It's a BIG difference and I would highly recommend it..
Old 03-25-11, 06:05 AM
mandyfig
mandyfig's Avatar
Plug and play? Can you please give me the numbers? All one size? Sorry for being lazy.
Old 03-27-11, 08:24 AM
jeffwingo
jeffwingo's Avatar
Just do a search on 'SC430 LED dome'
Most of what you will find will be nine or twelve led modules with three connectors.
My suggestion is to stick with nine led lights for the map/dome lights, but go with twelve for the trunk lights. Everything used the same type of connector except the map lights.
You can also get various colts based on your prefs from yellow to white to blue.
http://img.auctiva.com/imgdata/1/3/0...82439536_o.jpg
Old 03-27-11, 05:48 PM
mandyfig
mandyfig's Avatar
Thanks a lot.
Old 03-27-11, 06:19 PM
VIPNiSS
VIPNiSS's Avatar
Thanks a lot.
Mandy,
those are the ones I used as well. Although I don't recall how many LED's mine have but they are freaking bright!
Old 03-28-11, 02:49 PM
mandyfig
mandyfig's Avatar
I replaced my cabin filter yesterday and just found out my glove box light is not working. Bulb seems to be ok, checked it with my ohmeter. I checked the voltage across the connector, it is only giving me 0.18 volts when the switch is on...what's up with that? Should be 12V.
Needless to say was disappointed, thought was going to upgrade to LED's.
Quick Reply: Interior light help.
