Creaking Noise Going Over Bumps
Old 02-12-10, 10:32 AM
i2fat
i2fat's Avatar
Default Creaking Noise Going Over Bumps
I currently have a 2004 SC430 and was wondering if any of you guys have any problems while going over bumps and hearing a squeaking/creaking noise?
The noise is only present when I'm going over bumps, as I believe they have something to do with the suspension?
Could use some advice and anything I could do or have a mechanic do to get rid of the noise. Thanks!
(ITS REALLY BUGGING ME! )
Old 02-12-10, 03:38 PM
martini3
martini3's Avatar
Do a search...it's your friend on here and have been discussed before....
But since I gots some time, I'll help you out....
https://www.clublexus.com/forums/sc-...questions.html
https://www.clublexus.com/forums/sc-...h-feature.html
https://www.clublexus.com/forums/sc-...er-divets.html
https://www.clublexus.com/forums/sc-...op-noises.html
https://www.clublexus.com/forums/sc-...p-is-down.html
I can go on and on....but that should give you plenty to read...
martini3
Old 02-12-10, 05:54 PM
i2fat
i2fat's Avatar
Thanks martini3 for the threads!
Sorry I didn't use the search button :P
Hmm could they be the roof? How can I figure out if its the roof that's making the creaking noise and not the suspension? While driving it, I think it's coming from the wheel, but I could be mistaken.
Any other insights on the situation?
Old 02-13-10, 04:33 AM
azkaty
azkaty's Avatar
My 04 Jade creaks like crazy going over bumps.. it is the roof for sure..I know, cause it does not do it when the top is down!
Katy
Old 02-13-10, 08:45 AM
joeyb
joeyb's Avatar
Sounds like your struts. But there are a lot of things that cause similar sounds.
Try going to a parking lot with a speed bump. Drive over the bump slowly at an angle -- so that each wheel goes over the bump at a different time. This is what the mechanics at my dealer do to isolate the noise.
Old 02-13-10, 12:15 PM
i2fat
i2fat's Avatar
Thanks to the both of you
Old 02-13-10, 11:33 PM
Roofless
Roofless's Avatar
Is the creaking coming from the front of your car?
Old 02-13-10, 11:45 PM
i2fat
i2fat's Avatar
Yeah, it's coming from the front.
Old 02-13-10, 11:56 PM
Roofless
Roofless's Avatar
Had a similar problem. There's a high probability that it's actually your hood causing the creaking. Try raising the rubber hood stops to lift your hood.
Read this thread for more info:
https://www.clublexus.com/forums/sc-...r-problem.html
Here's a pic of the hood-stops locations (thanks talwang.)
Old 02-14-10, 12:02 AM
i2fat
i2fat's Avatar
I will definitely try that!
Thanks Roofless.
Loving the CL members and their helpfulness! Always giving me hope :P
Old 02-14-10, 07:02 AM
scdroptop
scdroptop's Avatar
Roofless-great tip and nice write up! Thanks for posting
Old 02-14-10, 11:27 PM
i2fat
i2fat's Avatar
How high should I lift it?
Old 02-15-10, 06:29 AM
rouge
rouge's Avatar
Default noise over bump
I had noise like that.
It coused by metal parts that support brake pad.
Please see my weblog.
http://uzz40.asablo.jp/blog/2008/11/17/4013890
Old 02-15-10, 07:52 AM
Roofless
Roofless's Avatar
1/8in. - 1/4in.
You'll be able to tell by the sound of the hood closing how snug your settings are.
Old 02-15-10, 04:31 PM
i2fat
i2fat's Avatar
I tried adjusting those and I still here a creaking/rattle noise. I can't tell if it is the tops fault because when I have the top down I can't hear the noise due to the wind lol.
Quick Reply: Creaking Noise Going Over Bumps
