I did a knuckle head thing.
Old 06-11-12, 08:48 AM
73446's Avatar
Default S.C.D. degree
Folks: The longer I read posts on this site, the more I think it should be required to have an "S.C.D.(Doctor of Sport Coupes) to own or operate a SC 430!!
Old 06-11-12, 01:00 PM
73446's Avatar
Question Now that you've mentioned it...
I've just assumed that its a bad idea to raise and lower the top with the engine off because of battery wear and tear. What do you folks think?
Mike
ps--I'm really impressed with this forum...others I've tried on other topics were disappointing because many seemed to assume that this was their primary venue for making others feel like asses. Thanks to everyone!
Old 06-11-12, 02:58 PM
tfischer
tfischer's Avatar
Operating the top with the engine off is discouraged not because of the load placed on the battery but because of the problems that would arise should the battery run out of juice during the process. Should that happen the car would not re-start, which would be bad enough. After a jump or a re-charge, of course, the battery would be just fine again, but the computers that control the top and that keep track of where all the moving parts are and which coordinate their movements could very well lose track of things. In such a case, the top would not open or close, as the case may be, and could even be frozen in between, in which case driving the car might be a problem. There is a process to manually close the top, but it is a pretty big undertaking, recommended for two or more.
The risk of any of these unpleasant things might be small, but you really never know the state of charge of the battery, and the solution - always have the engine running when operating the top - involves no risk, virtually no expense and hardly any inconvenience. In almost 12 years I have never operated the top with the engine running and have never had an inclination to do so. Even when I park the top half way to clean the inside of the rear window I leave the engine running the whole time.
Generally I think it's a bad idea because you might get into a giant problem which would be expensive and inconvenient to get out of.
Life is too short for that kind of stuff.
Old 06-11-12, 05:09 PM
JPBJR
JPBJR's Avatar
Thanks for that information about keeping the engine running. I did not know that and will follow your excellent advice.
Old 06-11-12, 05:51 PM
tfischer
tfischer's Avatar
I did not know it either when I bought the car, but it's pretty easy to figure out.
No epiphanal moment required.
Old 04-25-13, 06:33 AM
kennylexsc
kennylexsc's Avatar
thanks Habious, I saved it , maybe i don't have to use it, but very helpful
Old 04-25-13, 12:01 PM
Solman
Solman's Avatar
Originally Posted by KBALL
I was holding the roof button to lower the top when i was being introduced to a .....
Funny, I haven't held down that button since I installed luxlink five years ago. Also, the comment about not using remote start I disagree with. I always use it when I'm going to drive off with top down-saves the battery, not to mention the looks and comments you get from bystanders who watch as your top does its thing before you even get to your SC. Probably not your thing if you don't like attention. Lol
Old 04-25-13, 12:12 PM
mrblister
mrblister's Avatar
I read in the manual that they suggest the motor be running when operating the top.
Old 04-25-13, 12:28 PM
1sWt2GS
1sWt2GS's Avatar
pick up the luxlink alarm all your problems will be solved
Old 01-16-22, 10:22 PM
jszachar
jszachar's Avatar
Originally Posted by tfischer
You bet! I put a little white lithium grease on the moving parts. I use a spray can (because I use this on my garage door), but it's a mess to spray on such small spots, so I squirt a little into the top and use a Q-tip to apply it to the hinges and levers where they move against each other. My understanding is that WLG is preferred for this kind of an application because it does not run and drip. I gather it's pretty slippery.
Hiya there, tfischer. Would you please tell what WLG stands for. Thanks
Old 01-17-22, 05:09 AM
oneround
oneround's Avatar
Originally Posted by jszachar
White Lithium Grease
jszachar (01-17-22)
Old 01-17-22, 10:09 AM
jszachar
jszachar's Avatar
Many thanks, guys.
Old 01-17-22, 08:01 PM
jimisbell
jimisbell's Avatar
I always have to back the car out before lowering top or I pull into a parking place before operating it so the engine is always running. Cant think of a time that I would want to operate the top when the engine was not running?
But more importantly, I would NEVER want a device that let me put up the top or put it down without holding the button for 27 seconds.
That is a safety feature that was intended to be that way!!!!!! What happens when your child puts their hand where it doesnt belong and you have turned around to another task! With your hand on the button, stooping the action is instantaneous! If you value your and your guests safety, DO NOT USE A DEVICE that bypasses a safety feature!!!! To me, that would be a nuckle head action.
Old 01-17-22, 11:00 PM
NZBruce
NZBruce's Avatar
Thanks for the pdf , great to have it in the car
tempestv8
Hybrid Technology
25
06-13-18 04:28 PM
moskiter
11-05-09 02:30 PM
smokedawgs
RX - 1st Gen (1999-2003)
09-29-04 09:52 AM
gsfour
Performance
11-06-01 09:20 PM
Quick Reply: I did a knuckle head thing.
