SC- 1st Gen (1992-2000)
'95 SC300 suddenly will not start
Old 06-30-15, 09:14 AM
Fernage
Fernage's Avatar
Default '95 SC300 suddenly will not start
I bought and SC300 couple months ago and its been running great until today. I have driven it to school and back (~3 hour drive each way) numerous time without any issues. Yesterday I drove back to school and had no issues at all, but this morning I go to start it and it won't start. It seems like it is right about to start and it even seems to chug to life for a millisecond but it just won't get there.
Here is a video of a start attempt...
http://vid90.photobucket.com/albums/...psiw1w9jqm.mp4
Has anyone experienced this before? Any advice about what this could be would be greatly appreciated. Thanks in advance.
Old 06-30-15, 12:17 PM
eknine9
eknine9's Avatar
Check the cap and rotor on your distributor. They could be burned out which would cause this. They're cheap parts and relatively quick to replace.
Old 06-30-15, 04:14 PM
Fernage
Fernage's Avatar
Well now I really don't know what to think. I am at school and I don't have any tools so I was just checking things like fuses and disconnecting and reconnecting connectors for the coil and ignitor just to make sure its not loose. When I removed a spark plug wire I found that the spark plug valley has a bunch of oil in it, so I figure that my valve cover seals are bad and the oil is leaking down onto the spark plug tips and ruining them.
However, since I don't have any tools to fix this right now, just for the hell of it I tried to start it one more time and it started right up. It seems to be missing a bit when idling, which I think is probably due to the spark plugs being in bad shape from the oil, but I don't understand why it just decided to start again. Now I'm nervous that its gonna randomly go back to not starting.
Old 06-30-15, 10:14 PM
freakness
freakness's Avatar
Dude,
You need to repair the source of the oil leak which in this case appears to be the valve cover gaskets. Otherwise the problem will reappear.
- Chester
Old 07-05-15, 11:53 PM
Matromony
Matromony's Avatar
Check your timing as well
Old 07-06-15, 11:35 AM
ISFFUN
ISFFUN's Avatar
BTW to check your timing, use a light gun and make SURE you jump terminals TE1 and E1 first. Timing should be set at 10 degrees BTDC.
eddysara
Performance & Maintenance
03-18-18 01:00 PM
1992
09-18-17 07:08 PM
Reef13
17
11-23-15 07:45 AM
Candela
15
12-03-14 06:43 AM
Quick Reply: '95 SC300 suddenly will not start
