SC- 1st Gen (1992-2000)
Relay Locations on Kick Panel
Old 10-16-14, 08:19 PM
GISguy
GISguy's Avatar
Default Relay Locations on Kick Panel
I was wondering if anyone had a diagram showing exactly which relays on the kick panel are which. I have all fuses identified and, and details on the relays' states documented extensively on the FSM but not necessarily what it is physically on the kick panel.
I accidentally shorted a parking lamp wire for a split second, and now my tail lights, side markers, and parking lights are dead.
https://www.clublexus.com/forums/sc-...ml#post7896933
This post goes through various steps and how to narrow things down. All my fuses are fine, the diode is fine. The lamp failure module in the trunk seems fine (plus, wouldn't that only kill the tail lamps?). Aside from the integration relay (which I've ordered just in case), the tail light relay seems to be something to look at, but I'm not sure which it is.
Old 10-16-14, 10:02 PM
Joey-E
Joey-E's Avatar
Look up your User manual it will give you info where your fuses and relays are in the kick panel and engine bay.
http://drivers.lexus.com/lexusdriver...nual-search.do
Old 10-16-14, 10:23 PM
GISguy
GISguy's Avatar
Unfortunately no information about relays is given in those manual documents.
Old 10-17-14, 08:41 PM
Joey-E
Joey-E's Avatar
I believe its the black relay bottom right next to the fuses.
Old 10-19-14, 05:52 PM
GISguy
GISguy's Avatar
Thanks. So apparently, my fuse tester is wonky because the taillight fuse was out. Swapped it with a new 7.5A and voila.
Old 10-19-14, 07:40 PM
Joey-E
Joey-E's Avatar
Lol, glad you got it fixed.
slow92sc3
14
10-31-18 03:29 PM
SCYAL8R
15
04-01-13 09:07 PM
Nate008
02-21-12 04:13 PM
V8drummer
16
04-23-11 01:23 PM
mdwags
RX - 1st Gen (1999-2003)
07-14-09 09:18 AM
Quick Reply: Relay Locations on Kick Panel
