SC- 1st Gen (1992-2000)
daytime running light change to led?
Old 11-01-12, 02:27 PM
sidwin
sidwin's Avatar
Default daytime running light change to led?
just wondering can i change the DRL to LED? i know it dual purposes as high beams. I wouldn't mind making it a HID but i remember it can cause it to flicker when it acts as DRL. i want to change out to either LED something else to get rid of the last yellow light.
thanks,
sid
Old 11-01-12, 03:33 PM
xrsracer
xrsracer's Avatar
Yeah u can change it to led. I got my whole led kit from luxurymods.com
Old 11-01-12, 04:15 PM
Biologist
Biologist's Avatar
Im sure its been done before, and like xrsracer said LM is a good source in buying them, also try www.superbrightleds.com
Old 11-07-12, 09:25 PM
sidwin
sidwin's Avatar
ok i just changed mine to led but now they don't work as DRL. they work great as high beams but i bought them to be my DRL. what gives?
thanks,
sid
Old 11-07-12, 10:21 PM
Integra2SC
Integra2SC's Avatar
Day time running lights, if ran using the high beams, takes the normal voltage applied to the high beam and cuts it in half so if your car is running and your alternator is pumping a nice 13-14 volts that means your high beams are geting about 6.5-7 volts... which is probably not enough for the leds to light up.
Old 11-08-12, 06:40 AM
sidwin
sidwin's Avatar
ok so which led high beam are you all running that will work as drl? i changed every led out on the car and really don't want to have to go back.
Old 11-08-12, 06:44 AM
Kohinoor
Kohinoor's Avatar
thanks,
sid
you will need to use a relay to make led replacement bulbs work for the drl.
Old 11-08-12, 08:17 AM
thm8d
thm8d's Avatar
I bought LEDs off ebay and just ran a error free resistor one. Works for me!
Old 11-08-12, 09:20 PM
sidwin
sidwin's Avatar
Man that sucks. Guess I could find some 6v led...
matthew99
10-02-17 09:16 AM
Buggeroff6
12-30-15 07:17 AM
wpbmed
ES - 5th Gen (2007-2012)
09-20-11 05:04 PM
yoyokata
06-08-11 09:19 AM
envious
06-14-10 05:30 AM
Quick Reply: daytime running light change to led?
